Another thing to look for is the area of the bed or body above that spot will have fluid splattered on it. A tall tell sign it leaks.
you mean thats what that wet stripe above my front u-joint is - i never would have guessed actually i just resealed the rear of my tranny, but neglected to clean the underbody, so i don't know if it holds
Yeah pretty much. That can also sometimes be from the grease off the u-joint themselves. Since my Bronco has a stupid thing called a Double Cardon joint i have 3 u-joints on the rear driveline and one joint called a CV ball joint in the middle of it. It was a big PITA to replace. I have the same "line" above my transfer case and my rear axle, then you can see the splatter line on the front area where the front driveline is.
i know my stripe was at least partly ATF, but i think it also had a fair amount of grease in it. but a couple weeks ago when i was trying to diagnose my broken pinion gear that was howling but showed no other symptoms, i decided to replace the tranny rear seal and bushing, as well as both u-joints. fortunately, my van only has 2 u-joints, and both are the conventional style
Oh i see. I wish mine only had 2, i could have had the stupid thing done in a day rather than a week. Doesn't help when the parts store gets the wrong u-joints 3 times though. But that was being done while my trans was being rebuilt so i suffered through it.
This is the front side of the driveline
CV ball joint
The back u-joint. Most looked like this and were missing half or all the needle bearings...
I'm sure the new joints were the wrong ones here but i was so fed up once i got the right ones i didn't take a picture. I just wanted it done.
Gruesome - thanks for the advice. I'll crawl under there this weekend and look for splatter. I can't believe I didn't think of that trick.
No problem, it is more of a cleanliness thing for me, i don't clean it up per say but i like to know it's there so i don't touch it if i am not trying to get real dirty.
Well have a good weekend guys. My plan is tomorrow bright and early to go help fix a Buick, then off to a grad party for a friend. After that i will probably end up working on TGM for a bit.
Subject: The daughter's last request at this house.....
My daughter walked into the family living room last night and said, "Dad,
cancel my allowance immediately, forget the college tuition, rent my room
out, throw all my clothes out of the window; take my TV, iPhone, iPod, and
my laptop. Please take any of my jewelry to the Salvation Army or Cash
Converters. Then sell my car, take my front door key away from me, and throw
me out of the house. Then disown me and never talk to me again. And don't
forget to write me out of your will and leave my share to anyone that wants
it."
Well... she didn't put it quite like that. She actually said...
"Dad, meet my new boyfriend, Muhammed. We're going to work together on
President Obama's re-election campaign."
