Washington Chapter Washington Chapter
Join Chapter, Leader: Tim Young
WAFTE June B.S. Thread
Old Jun 27, 2012 | 08:36 PM
  #136
GruesomeJeans's Avatar
GruesomeJeans
Anyone got any useful pointers for doing struts on a front wheel drive chevy malibu? I get to help a friend who barely knows how to change his oil, do his shocks and struts... I have never used that kind of spring compressor other than the small one for valve springs.
Old Jun 28, 2012 | 02:35 AM
  #137
joshofalltrades's Avatar
joshofalltrades
grease your spring compressor, and don't force it too hard. when i can, i like to set the strut assy in a hydraulic press, and use that to do most of the work, as the little spring compressors tend to have wear issues under load. i assume you're using the compressor thats 2 pieces of all thread with hooks on them, one piece mounted to each side of the spring - yeah, they're decent at holding the load but i've had them lock up on me before, which is why i use the press to do most of the work. grease helps prevent this in most cases, but lockup sucks
Old Jun 28, 2012 | 05:29 AM
  #138
67gt351's Avatar
67gt351
Good morning Washington ! Hope everyone has a great day!
That's a nasty job Dylan, did it on gti, use caution on those springs!
Old Jun 28, 2012 | 12:20 PM
  #139
GruesomeJeans
I am pretty sure it is that style, i don't have a hydraulic press to use though. The ones i saw the shops use were these big metal encased arms on a threaded pole that you align on the spring and then ratchet down. And even those are dangerous.
So pretty much the plan now, is to call down to a shop my brother worked at and get a quote from his friend to see how much it would be to do the struts, then do the rear shocks at my house and take it there to get those done. I got a really unsafe feeling after thinking about that coil popping loose or the compressor failing. It would be easier and safer to both of us just to pay someone the bit of money to do it real quick.
Good afternoons BTW
Old Jun 28, 2012 | 10:56 PM
  #140
onug's Avatar
onug
Good evening everyone. I picked up a bunch of fluids from Horizon Ford (where PartGuyEd used to work) today. Looking forward to doing some maintenance soon, just need to find the time.
Old Jun 28, 2012 | 11:24 PM
  #141
GruesomeJeans
Sounds like fun onug, i get to do more carb work tomorrow. I have to find a manual for mine so i can find the low idle screw. It started off a little messed up. then it got messed up more. Then i poked at it and got it even worse. Then today while hanging out at the park with a few friends i jumped in the engine and set the timing back without a light and played with the screws enough to get it running almost good. The issues now are it starts shuddering when i hit the brakes at a light or stop sign, and it seems to be missing or the ignition timing is still off a bit.
I am proud i was able to fix my own mistake, i have a hard time understanding the carburetor "features"
Old Jun 29, 2012 | 01:58 AM
  #142
crash1's Avatar
crash1
good evening everyone i'm late as usual...LOL
Old Jun 29, 2012 | 02:28 AM
  #143
joshofalltrades
Good afternoons BTW
sounds like you'd rather be safe then wake up in a hospital somewhere... can't say i blame you!
the other option you have is to buy the strut assy pre-assembled from your local parts store. they obviously cost more up front, but may cost less than the labor for someone else to do it
  #144
GruesomeJeans
You know, i worked with a mexican guy once (no offense to the spanish) and he said mexicans are always late, you tell them 2:00 they will be there at 2:10. Maybe you got spanish blood in you Crash
Old Jun 29, 2012 | 02:35 AM
  #145
crash1's Avatar
crash1
lol very funny..No i have been getting the truck ready for a show
Old Jun 29, 2012 | 03:32 AM
  #146
GruesomeJeans
Ah ok, which one? the big one or the bigger one?
Old Jun 29, 2012 | 03:38 AM
  #147
crash1's Avatar
crash1
the bigger one
Old Jun 29, 2012 | 04:24 AM
  #148
GruesomeJeans
Oh ok. That should be fun.
Old Jun 29, 2012 | 09:00 AM
  #149
caseys's Avatar
caseys
xxxxxxxxxx
Old Jun 29, 2012 | 09:45 AM
  #150
crash1's Avatar
crash1
LOL good one
