CAI vs. SRI
Old May 31, 2012 | 03:40 PM
MrThinroyy's Avatar
MrThinroyy
CAI vs. SRI
I'm sure this has been on here a few times, but I'm looking for a few opinions. With my current truck (a 2000 Excursion, FTW) successfully murdering my wallet, I'm looking into a late 90's, early 00's ranger, with the V6, 4x4, and I want a lil' extra umpf for her. I've read plenty of threads and reviews on Cold Air vs. Short Rams, and I'm still on the fence. I'm looking for one that'll give me better torque at lower RPM's (for light mudding and things like that), but I don't want the heat soak to hurt it too bad if I'm on longer trips. They both have their pros and cons, but I wanna hear what some people who actually have the intakes think.
Old Jun 1, 2012 | 01:04 AM
bankshot's Avatar
bankshot
They both suck, literally. Stick with stock.
Old Jun 1, 2012 | 02:00 AM
critterf1's Avatar
critterf1
The stock set-up flows plenty of air.
Old Jun 1, 2012 | 02:05 PM
MrThinroyy's Avatar
MrThinroyy
Well after your responses, and some more looking into it, what would you suggest for more power? Exhaust, tuner, HEADERS, gearing? And could you list possible price rangers for them as well, please?
Old Jun 1, 2012 | 11:11 PM
KhanTyranitar's Avatar
KhanTyranitar
Shy of major engine mods, a complete exhaust system and a tuner (yes i takes all three to really make any difference at all), you aren't join to get much in the way of any real world gains.
By major engine mods, you need to remove the cylinder heads, get them ported and matched, port and match the intake, do some minor porting on the exhaust manifolds if you want or get some headers, then get a tuner and dial in a tune to better take advantage of your mods. Thats gonna get a good start that will deliver real results. If you want to step beyond that, you will either need a different cam, or you will need to go forced induction.
Regardless, its pointless to soup up the engine unless you also soup up the trans to handle it. The manual trans is fine even with the stock clutch, just keep up on the maintenance. The automatic needs to be upgraded or it will not hold up to anything beyond stock output for long. You need a shift kit, valve body calibration, and possibly better clutches. These things by the way, also increase the amount of engine power that reaches the wheels slightly, and generally improve throttle response.
Old Jun 2, 2012 | 12:58 AM
michigan66's Avatar
michigan66
If you want more power, look for a Ranger with the 4.0 engine, keeping in mind that with more power, fuel mileage is lessened.
volkrt
Jan 11, 2017 04:51 AM
EPI-911
May 5, 2014 11:00 AM
F250AKtoTX
6.4L Power Stroke Diesel
Dec 2, 2013 10:20 AM
usmc17
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
May 18, 2008 12:49 PM
speedracer66
Feb 14, 2004 10:39 PM
