I see in many posts that people recommend to get injectors from Russ(typ4) but I don't understand how to find this contact information. I have a 94 with the factory turbo. Also are the BB injectors what I want?
Yes, you want BB code injectors for any IDI. Send Russ a PM. Try the username typefour
For what it is worth i got mine at pensacola 148.00 they did tell me that i didnt want the bb injectors because they were not for the turbo engine mine is a 94 as well
Are you looking for stock or performance? Dps sells a perfromance upgrade pump and injectors. If you are looking for stock injectors, go with the BBs from Russ. You can get ahold of him easily at OBN. As for the BBs most think they perform better on a turbo engine than the stock turbo injectors. I can't remember why the prefer them though...
I have the injectors and like them a lot. There are quite a few guys on here that have them. I know RacinNdrummin has the injectors and used to have the pump and NMB2 has the injectors also but he is running a way bigger pump than we are. He is running a Db4...
I have never found any "proof" that BB's are any more desirable than any other injector. However with that being said the general consensus is BB's are a better injector, and that the G codes (turbo engines) are a emissions friendly injector. The BBs seem to be cheaper and more available as well. I do in fact wonder what the difference is exactly between the injectors used throughout the years, cant be too much of a mystery, could be something as simple as pop off pressure.
