thoughts?
Old May 30, 2012 | 06:10 PM
adam10's Avatar
adam10
thoughts?
first question 01 f-350 srw extended long bed auto. totally stock. is 14 mpg a good average for mixed town and highway driving no hauling or towing?(averaged 13.3 towing 30 ft. layton and hauling loads of campfire wood.happy with that.)
second i plan on doing exhaust and intake as soon as cash flow makes it possible but should i install guages first?
Old May 30, 2012 | 06:14 PM
Shake-N-Bake's Avatar
Shake-N-Bake
14 mpg is about what you can expect for mostly city driving.
17 mpg is about what you can expect for mostly highway driving.
At least that's how it's been working out for me so far...
Old May 30, 2012 | 06:43 PM
adam10's Avatar
adam10
thanks for the info havnt had it on a highway trip yet.would like to because the get up and go is alot better
Old Jun 1, 2012 | 07:19 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Don't need gauges until you add a tuner or programmer. Stock it shouldn't peak the egt's. 4" exhaust is plenty and the 6637 kit from Clay 500$ tops.
Old Jun 1, 2012 | 08:59 PM
WA.Ranger's Avatar
WA.Ranger
X2! I would get the exhaust and intake first. Then I would plan on getting a Valve body from JW or BTS.
Old Jun 1, 2012 | 10:00 PM
Tugly's Avatar
Tugly
One thing you can do before you decide on where to spend: Look for soot near any exhaust component under the hood. An exhaust leak will rob you of power and economy. Before my Buck$Zookafest, I got 15.5 city/hwy and 17.5 on the highway, now I get 17.5 city/hwy and over 19 hwy... with the ability to rip ricers when I chose.
Old Jun 1, 2012 | 10:50 PM
crazymut's Avatar
crazymut
Also while doing exhaust you might want to look at doing the bellows type of pipe to the turbo
Old Jun 2, 2012 | 12:11 AM
jccapri's Avatar
jccapri
What is a bellows pipe
Old Jun 2, 2012 | 12:14 AM
BigAlsPSD's Avatar
BigAlsPSD
Upgraded up pipes that eliminate the slip joint style that are prone to leak.
Riffraff Diesel: International Bellowed Up-pipe Kit 99.5-03
Old Jun 2, 2012 | 12:19 AM
WA.Ranger's Avatar
WA.Ranger
Good call Terry!
Old Jun 2, 2012 | 12:31 AM
crazymut's Avatar
crazymut
Just thought while in there it's a good time to tackle it. And there would be a little more room to do things while the exhaust is out to be changed.
Old Jun 2, 2012 | 04:43 AM
Tugly's Avatar
Tugly
Bellowed up pipes are pre turbo and they aren't cheap. My truck had exhaust leaks on every component between the turbo and the block after 200K miles, so everything was replaced and that was my first bump in economy and power. If you don't have exhaust leaks, you will later - but I would not replace a properly functioning pre-turbo exhaust component.
Old Jun 2, 2012 | 02:35 PM
crazymut's Avatar
crazymut
Being an 01 I would almost. bet it's leaking already.
Old Jun 3, 2012 | 04:24 PM
adam10's Avatar
adam10
thanks for the tips.when i was degreasing my engine i looked for soot and didnt see any around the up pipes.but i will check again before doing any other things.mine only has 109,000 on it yet.hopefully many more miles to come
19-kilo
Jun 17, 2011 03:59 PM
A/Ox4
May 21, 2011 08:13 PM
Sirpontiac
May 7, 2007 12:30 AM
ponch37300
18
Jun 7, 2006 11:07 AM
hink10
Oct 30, 2005 09:23 PM
