M100 replacement clips
Old 05-31-2012, 06:39 AM
2quickM100's Avatar
2quickM100
2quickM100 is offline
Has anyone found any factory replacement spring clips that hold the chrome trim strip to the bottom fronted grill valance? I could probably just find something that would work....but I wanted this build especially front end be original as possible. The reason the strip needs to be used is that the grill I'm using is the mercury grill and the bottom bolts holes used to attach the lower ford grill are replaced with a spring wire clips that holds the chrome trim down on the mercury one.
Thank you for your reply.
Old 05-31-2012, 06:42 AM
2quickM100's Avatar
2quickM100
I quess it would have helped putting the year of the truck in...1960 M100
Old 05-31-2012, 06:35 PM
spurredon's Avatar
spurredon
spurredon is offline
Minor technicality! Welcome to FTE!!
Steve56
1999 to 2016 Super Duty
07-05-2019 01:59 AM
1950FordF1
12-30-2015 08:51 PM
shotgun
10-23-2008 12:57 AM
willowbilly3
10-26-2003 06:40 PM
Quick Reply: M100 replacement clips
