M100 replacement clips
Has anyone found any factory replacement spring clips that hold the chrome trim strip to the bottom fronted grill valance? I could probably just find something that would work....but I wanted this build especially front end be original as possible. The reason the strip needs to be used is that the grill I'm using is the mercury grill and the bottom bolts holes used to attach the lower ford grill are replaced with a spring wire clips that holds the chrome trim down on the mercury one.
Thank you for your reply. |
I quess it would have helped putting the year of the truck in...1960 M100
Originally Posted by 2quickM100
(Post 11896484)
