drip rail trim
Old Oct 25, 2003 | 02:28 AM
willowbilly3's Avatar
willowbilly3
drip rail trim
I found a 72 with perfect driprail trim and I was wondering if anyone here knows how to get it off without damaging it.
Also how do you get the chrome trim out of the way on a 71 (72 ?) grille so you can get at the screws that hold the grill in. I am talking the fancy grills, not the plane ones.
Old Oct 25, 2003 | 07:12 PM
idealtrucks's Avatar
idealtrucks
the headlight bezels just come off with screws, and the main bolts that hold on the grill are located on the backside. Under the front fender.
Old Oct 25, 2003 | 08:48 PM
willowbilly3
I meant the plastic grill inserts, not the grille surround. I have changed all that out on a couple of 72s but I found a 71 Ranger with chrome strips on the plastic grille inserts and I can't see how to get the chrome off so I can get at the screws. I even pried it off a broken grill to see how it was held on and I still can't see how to release it.
Old Oct 25, 2003 | 11:27 PM
71_4x4_390's Avatar
71_4x4_390
willowbilly3
Hey I'm assuming you got this trim to put on a different truck. I have the same trim that I got from a specialty scrap yard. I paid too much for it, but it was in good condition. I'm dreading installing it on my truck, and damaging the trim and/or scratching up the paint. Be a good guinea pig and let us know how hard it is to reinstall!
Old Oct 26, 2003 | 01:28 AM
willowbilly3
Hey, I will do just that. It likely won't cost anything if I get it with some other stuff. Then I will try to put it on my 68 F-250 which I have decided to leave as a beater, and just buy a nice low mileage one. My "beater" will how ever be getting a/c and p/s and a brake upgrade to at least a power booster. I might also chiunk the 240 if I find a decent running 300 for cheap.
Old Oct 26, 2003 | 05:16 PM
comet's Avatar
comet
That chrome strip through the middle of the '71 grilles is essentially a spring clip. Grab it with both hands, thumbs up and fingers on the underside of the chrome piece and the thumbs on the plastic on the top side. Pull up with your fingers and it will clear the retaining clip. While holding it up over the retaining clips (at the same time), pull out with your thumbs. Snaps back in in reverse order.
Old Oct 26, 2003 | 06:40 PM
willowbilly3
thanks comet
