Driveshaft phasing...
Old May 31, 2012 | 07:16 PM
Cell's's Avatar
Cell's
So my truck has a 2 piece drive shaft . The rear u-joint and the middle u-joints retaining clips are positioned the same way and the front u-joint retaining clip is 90 degrees offset .??
From my understanding of "Phasing" , the front u-joint and the rear u-joint should be set the same way ??
Does this sound right to you guys ??
Old May 31, 2012 | 08:01 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
The front yoke and the yoke on the slip joint should be the same, just like the rear drive shaft, they're welded the correct way.
spdmpo
Nov 13, 2014 07:41 PM
Freddy.ca
Oct 1, 2012 01:42 PM
gladesteen
Nov 4, 2008 12:13 AM
bubbasz1
Apr 3, 2008 08:03 AM
85 F-350CrewCab
Sep 12, 2004 11:00 PM
