Driveshaft problems
Old Sep 30, 2012 | 01:42 PM
Freddy.ca's Avatar
Freddy.ca
Driveshaft problems
86 ford F250 deisel 7.3 ext cab 4x4. been having problems with the tailshaft vibration, replaced both u-joints once. had the nut back off a titch on the rear yoke and had to replace the back u-joint again. vibration seemed to come and go. blew the tailshaft off the other day doing 90km hr down the highway. i'm looking at replacing the whole shaft with something stonger? better than original, maybe off a newer truck. what else might fit or come close to machine? or i could replace just the tailshaft
Old Sep 30, 2012 | 04:57 PM
Rovernut's Avatar
Rovernut
I can't offer any specifics since I'm just getting familiar with Fords again, but just general driveshaft comments.
Did you have it balanced after replacing the u-joints? I've seen driveshafts throw balance weights (or knocked off when off-roading).
Were the u-joints seized and causing vibration?
Extended driveshaft vibration can cause transfer case output bearing or pinion bearing damage which can cause vibration even after the driveshaft is fixed.
I can't remember what the locknuts are like on the u-joints but many locknuts should be replaced with new. And even if multiple use, it's cheap insurance.
Old Sep 30, 2012 | 08:43 PM
Franklin2's Avatar
Franklin2
Replacing the tailshaft with a good one may solve your problems. Make sure your slip yoke(if that's the type you have) is good also. If you have the slip yoke style, there is a bushing in the tailshaft that supports the yoke, and if these pieces are worn, will let the the shaft vibrate, especially when you are in that "inbetween" state on the gas pedal, with no load on it going down the road.
Old Sep 30, 2012 | 09:26 PM
Freddy.ca's Avatar
Freddy.ca
the original u-joints that we replaced were worn with age, that was 4 months ago and things were ok till the pinion yoke nut came loose and the closest ujoint shattered and it was then that the vibration persisted im thinking that the front yoke on the shaft had a hairline crack. thats what broke and split.
I need a new tailshaft and at the same time i'll drop the front shaft and have the bushing replaced for now. is there any other year of ford that would fit this truck?
Old Oct 1, 2012 | 07:58 AM
Franklin2's Avatar
Franklin2
Here are all the different combos of shafts for a 1985 f250. You need to know your wheelbase to narrow it down a little bit. Go to Car-Part.com--Used Auto Parts Market where I got this info, plug in your truck, Georgia and pick the right shaft, and see if anyone has any down there. It will do the interchange for you also(it will select other years in the left column automatically).
155" WB, M.T., 4x2, Fr section, New Process
155" WB, A.T., 4x4, Fr section
133" WB, M.T., 4x2, one-piece, New Process, Spicer axle
133" WB, M.T., 4x2, one-piece, Warner, Spicer axle
133" WB, M.T., 4x2, two-piece, Fr section, New Process
133" WB, M.T., 4x2, two-piece, Fr section, Warner, T-18
155" WB, M.T., 4x2, Fr section, Warner, T-18
161" WB Chassis Cab, A.T., Fr section
161" WB Chassis Cab, A.T., Rr section
161" WB Chassis Cab, M.T., Fr section, New Process
133" WB, A.T., 4x4, slip yoke joint, Spicer axle
133" WB, M.T., 4x4, slip yoke joint, Spicer axle
155" WB, A.T., 4x2, Fr section
155" WB, M.T., 4x2, Fr section, Warner, T-19
155" WB, M.T., 4x4, Fr section, New Process
155" WB, M.T., 4x4, Fr section, Warner, T-18
155" WB, M.T., 4x4, Fr section, Warner, T-19
161" WB Chassis Cab, M.T., Rr section, New Process
133" WB, A.T., 4x2, one-piece, AOD
133" WB, A.T., 4x2, one-piece, C6, Ford axle, 10 bolt cover
133" WB, A.T., 4x2, one-piece, C6, Ford axle, 12 bolt cover
133" WB, A.T., 4x2, one-piece, C6, Spicer 61 axle
133" WB, A.T., 4x2, one-piece, C6, Spicer 70 axle
133" WB, A.T., 4x2, two-piece, Fr section, AOD
133" WB, A.T., 4x2, two-piece, Fr section, C6
133" WB, A.T., 4x2, two-piece, Rr section, Ford axle
133" WB, A.T., 4x2, two-piece, Rr section, Spicer axle
133" WB, A.T., 4x4, flange joint, Ford axle, from 5/85
133" WB, A.T., 4x4, flange joint, Ford axle, thru 4/85
133" WB, A.T., 4x4, flange joint, Spicer axle, from 2/85
133" WB, A.T., 4x4, flange joint, Spicer axle, thru 1/85
133" WB, A.T., 4x4, slip yoke joint, Ford axle, from 2/85
133" WB, A.T., 4x4, slip yoke joint, Ford axle, thru 1/85
133" WB, M.T., 4x2, one-piece, New Process, Ford axle
133" WB, M.T., 4x2, one-piece, Warner, Ford axle
133" WB, M.T., 4x2, two-piece, Fr section, Warner, T-19
133" WB, M.T., 4x2, two-piece, Rr section, Warner T-19, Ford axle
133" WB, M.T., 4x2, two-piece, Rr section, Warner T-19, Spicer axle
133" WB, M.T., 4x2, two-piece, Rr section, exc. Warner T-19; Ford axle
133" WB, M.T., 4x2, two-piece, Rr section, exc. Warner T-19; Spicer axle, over 8500 GVW
133" WB, M.T., 4x2, two-piece, Rr section, exc. Warner T-19; Spicer axle, under 8500 GVW
133" WB, M.T., 4x2, two-piece, assm (Warner T-19 & Ford axle)
133" WB, M.T., 4x4, flange joint, Ford axle, from 5/85
133" WB, M.T., 4x4, flange joint, Ford axle, thru 4/85
133" WB, M.T., 4x4, flange joint, Spicer axle, from 2/85
133" WB, M.T., 4x4, flange joint, Spicer axle, thru 1/85
133" WB, M.T., 4x4, slip yoke joint, Ford axle, from 2/85
133" WB, M.T., 4x4, slip yoke joint, Ford axle, thru 1/85
155" WB, A.T., 4x2, Rr section, Ford axle
155" WB, A.T., 4x2, Rr section, Spicer axle
155" WB, A.T., 4x4, Rr section, Ford axle
155" WB, A.T., 4x4, Rr section, Spicer axle
155" WB, M.T., 4x2, Rr section, New Process, Ford axle
155" WB, M.T., 4x2, Rr section, New Process, Spicer axle
155" WB, M.T., 4x2, Rr section, Warner T-18, Ford axle
155" WB, M.T., 4x2, Rr section, Warner T-18, Spicer axle
155" WB, M.T., 4x2, Rr section, Warner T-19, Ford axle
155" WB, M.T., 4x2, Rr section, Warner T-19, Spicer axle
155" WB, M.T., 4x2, assm (T-19, from 6/85)
155" WB, M.T., 4x4, Rr section, Ford axle
155" WB, M.T., 4x4, Rr section, Spicer axle
161" WB Chassis Cab, M.T., Fr section, Warner, T-18
161" WB Chassis Cab, M.T., Fr section, Warner, T-19
161" WB Chassis Cab, M.T., Rr section, Warner, T-18
161" WB Chassis Cab, M.T., Rr section, Warner, T-19
161" WB Chassis Cab, M.T., assm (T-19, from 6/85)
Old Oct 1, 2012 | 01:42 PM
Freddy.ca's Avatar
Freddy.ca
Found a match here in town for 80 bucks complete shaft. but ya its a 155" WB two piece shaft with slip yoke
helirich
1978 - 1996 Big Bronco
Feb 8, 2008 02:13 PM
Micginish
34
Oct 13, 2005 11:24 PM
pdqford
Oct 31, 2004 10:07 PM
150ford
Jul 17, 2004 09:47 AM
cpettymore7777
Jan 2, 2004 10:01 PM
