compressor wheel
Old May 30, 2012 | 11:40 AM
Fireman_dave's Avatar
Fireman_dave
compressor wheel
Has anyone ever changed the compressor wheel on their idi turbo...i need to change mine...a d it looks like I can just run the nut off and pull it out and replace it
Old May 30, 2012 | 04:22 PM
tecgod13's Avatar
tecgod13
To properly do this, you have to pull the turbo, and disassemble it so the shaft assembly (shaft and two wheels) can be balanced.
Old May 30, 2012 | 04:40 PM
NMB2's Avatar
NMB2
Not always. I'm not sure if Garrett chargers are the same, but BW chargers are zero balanced. You can swap out any individual piece.
Old May 31, 2012 | 12:41 PM
eatont9999's Avatar
eatont9999
Yep, some turbos have the shaft and wheels balanced together and some are balanced independently. We really need to know what kind of turbo you have. Is your wheel damaged or are you trying to get more boost with a different wheel?
You are going to at least have to take off the down pipe because you need to put a socket on the impeller wheel in order to get the nut off the compressor wheel. Then you will need to torque the new wheel down to spec. In most cases, you also have to take the compressor housing off to remove the compressor wheel.
Old May 31, 2012 | 03:05 PM
tecgod13's Avatar
tecgod13
Ah, didn't know that. I figured one of you turbo guru's would be along with more info anyways.
2000F250guy
Nov 7, 2013 06:51 PM
paddler
Dec 9, 2012 10:16 PM
dt444e
18
Aug 8, 2009 11:32 AM
mueckster
Dec 24, 2003 07:07 PM
jwillson4
Jul 28, 2003 01:20 PM
