oil cosumption
Old May 31, 2012 | 01:30 PM
gumper 123's Avatar
gumper 123
oil cosumption
Well i am thinking this old truck is ready for a rebuild unless you all have a better thought going through 2 quarts every 500 miles very minor leaks at valve covers chaged out cdr valve checked and tested new cdr seems fine acourding t test old truck still runs good but thinking this could be do to the oil burning what do you all think. It now has 295,450
Old May 31, 2012 | 03:07 PM
tecgod13's Avatar
tecgod13
How are you checking the oil?
Proper procedure is have the engine warm (operating temp), turn off and wait 10-15 minutes for the oil to drip down to the pan. Then check the level.
The line on the dipstick means two quarts low, but it doesn't mean you have to top it off all the time. If kept at the upper end of the dipstick, the oil tends to burn off quicker.
Old May 31, 2012 | 03:43 PM
gumper 123's Avatar
gumper 123
Well I always check it warm and when I top it off put it on the full mark but when I check it a couple weeks later below the checkerd line two quarts
Old May 31, 2012 | 05:56 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
can you post the symptoms of the truck?
like when you first start it,does she blow out a lot of blue smoke,or do you get more blue smoke when your coming onto her up a hill?
did you do a compression test yet? if so,what are the results?
could just be time to freshen up the heads depending on whats happening.she has gone about the length of 3 460's,so it could be time to freshen up the whole works lol.
lordyfordy
3.8 & 4.2L V6
Apr 3, 2023 05:13 PM
Gregxlt
1997 - 2003 F150
Apr 23, 2013 07:18 PM
jeff9942
Oct 10, 2009 03:00 PM
bob arrington
Nov 21, 2005 07:29 PM
BigBlackSuperCrw
1997 - 2003 F150
Jan 27, 2005 08:56 PM
