AE, abs bleeding
Old May 29, 2012 | 06:54 PM
trekbasso's Avatar
trekbasso
AE, abs bleeding
Will an AE perform the bleed procedures for an abs repair?
Looking for one more reason to buy one now vs later.
Thanks.
Old May 29, 2012 | 08:58 PM
woodnthings's Avatar
woodnthings
AE has the option to perform a service bleed. You will have to have the steps required to get it to work. The NGS scanner Ford uses, walks you through the procedure. AE just runs and says it has failed the test. If you place your foot on the pedal, it does go to the floor then gives you a fail. Like many of the tests the truck is capable of, you need to know the logic sequence to make them work properly.
Old May 30, 2012 | 07:45 AM
trekbasso's Avatar
trekbasso
Thanks Ken, looks like more research is necessary.
LeRoy l
May 1, 2017 10:04 AM
A/Ox4
Jun 17, 2011 08:31 AM
84-250
General Automotive Discussion
Mar 14, 2008 01:58 PM
gabocar
Nov 4, 2006 07:54 PM
jetjock16
Jan 10, 2003 07:50 AM
