Sponsored by: Real Truck
Abs modual valve
Old Apr 30, 2017 | 08:58 AM
LeRoy l's Avatar
LeRoy l
Abs modual valve
Been told that my abs modual is bad. Been looking at it and have a couple questions.
When I change it do I need to reprogram.
Do I remove the water reservoir and do it from top or remove fender lining and do it from wheel well..
There are on codes showing or abs light on.
Have bread the brakes and have good pedal but let it set a couple minutes and the pedal goes to the floor.
Any help would be appreciated.
Old Apr 30, 2017 | 09:57 AM
alloro's Avatar
alloro
Originally Posted by LeRoy l
Been told that my abs module is bad.
Based on what...in other words, what symptoms are leading someone to tell you the ABS module is no good?
Old Apr 30, 2017 | 04:15 PM
LeRoy l's Avatar
LeRoy l
Put new brakes all the way around. Had to replace rear passenger caliper. When finished bled brakes starting at rear pass then rear driver then frount pass then driver. Hard peddle but after setting peddle goes to floor. You can pump it up to hard pedal but goes back down.
I used a clamp to return brake calipers and did not open bleeders was told I might have damaged abs modual.
Had no issues before putting on new pads and caliper.
Without the engine running I have a good pedal. Once you start the truck the pedal goes to the floor.
No ABS light or codes.
Master cylinder ?
Abs Module ?
Help!!
Old May 1, 2017 | 10:04 AM
alloro's Avatar
alloro
Sounds like the ABS module is fine and that you still have air in the system.
Havas E
1997 - 2003 F150
Jan 11, 2017 02:34 PM
Diesel-N-Bucket
Dec 14, 2011 06:36 AM
f-250diesel
Jan 12, 2010 01:14 PM
XylemXorro
Mar 26, 2007 01:31 PM
dufrain
Aug 17, 2006 08:58 AM
