Early 2002 Explorer intermittant wont start issue
  #31
Old 06-16-2016, 07:05 AM
shorod's Avatar
shorod
shorod is offline
I know this isn't a guarantee, but your symptoms are VERY consistent with a failing fuel pump. But if you want to be sure, you're going to need to carry a few tools with you and understand how to use them. First would be a fuel pressure gauge to check for fuel pressure at the fuel rail when the problem occurs. Next would be a multimeter or test light to check for voltage to and through the fuel pump inertia switch.
Once you know how each of those are performing, further diagnosis can proceed.
If you plan to fix and keep the truck for awhile, you might want to replace the fuel filter to make sure that's not just plugged up, but that wouldn't be heat sensitive, just good maintenance.
-Rod
Rus01
10-23-2010 05:41 PM
Johnny one
20
11-20-2005 02:42 AM
TWolf
12-25-2004 10:39 PM
zeppo
04-25-2004 10:00 PM
cobra413
07-05-2003 08:29 AM
Quick Reply: Early 2002 Explorer intermittant wont start issue
