79 4x4 steering
Old Jun 1, 2012 | 11:27 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
In terms of semantics, that thing IS a u-joint.
http://en.wikipedia.org/wiki/Universal_joint
"A universal joint, universal coupling, U-joint, Cardan joint, Hardy-Spicer joint, or Hooke's joint is a joint or coupling in a rigid rod that allows the rod to 'bend' in any direction, and is commonly used in shafts that transmit rotary motion. It consists of a pair of hinges located close together, oriented at 90° to each other, connected by a cross shaft."
In terms of civility, cool it.
Old Jun 1, 2012 | 07:26 PM
customrich&matt's Avatar
customrich&matt
comeon guys play nice
Old Jun 1, 2012 | 07:49 PM
HIO Silver's Avatar
HIO Silver
Universal joint - Wikipedia, the free encyclopedia
Cooled, but...
I can play nice and am normally respectful. However, I will not sit idle and have someone correct me in a way that is not only incorrect, but rude and condescending.
I have been in contact with an FTE moderator. We've discussed the issues and I'm still here. That should answer any of questions on the status of my participation.
Old Jun 1, 2012 | 08:41 PM
kobaltblue's Avatar
kobaltblue
Originally Posted by marmon77
Checked my power steering fluid yesterday while truck was running because there was a "whine" when I turned the wheel. When I opened the resevoir I could barely see any fluid but when I shut it off to add fluid it was back at the top. Is this normal? Thanks
Yes it will drop down well the pump is running and come back up...Dont over fill it it will all end up on the ground it should be about a half inch up the tube well running.......
I love it you guys are arguing like babys about someone else stuff but not answered his question.....But I get scolded for accidentally hitting the caps key!
Priceless!
So now can you get back to what the guy was asking about!
Old Jun 1, 2012 | 08:43 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
If the thing wiggles in that area that everyone is arguing about then replace the whole shaft. The End. Good luck.
Old Jun 1, 2012 | 09:45 PM
Cory281's Avatar
Cory281
I just replaced my steering shaft. The coupler next to the gear box was worn out and so was the u-joint. The bearing at the end of my steering column was also bad, so was the white plastic cap that held it.
I ended up getting a new shaft, so that fixed the sloppy coupler and replaced it with a u joint. LMC truck has the bearing that goes in the bottom of the column, I also ordered the plastic cap from them, but it was the wrong one. The 2wd caps are different from the 4wd ones. The one I got was for a 2wd, I ended up finding a good on at the junk yard. If your bearing is bad, make sure you get a rubber sleeve that goes around the bearing that holds it into place inside the plastic cap.
If that doesn't make any sense, I'll clarify later.
Old Jun 1, 2012 | 10:13 PM
ManfredVonRichtofen
Man, I wish I knew you was going to buy that one in LMC. Would have told you it was the wrong one.
Old Jun 2, 2012 | 09:35 AM
marmon77's Avatar
marmon77
Thanks for the reply's, I haven't gotten back to the steering, I've been dealing with drive shaft issues,but when I do I'll follow the advise here.
Old Jan 5, 2013 | 10:44 PM
HIO Silver's Avatar
HIO Silver
Case in point.... exempli gratia
"Ignoratorum versatusque est"
gochappy
Sep 19, 2017 09:59 AM
Fish_Scientist
24
Jul 20, 2017 10:57 AM
chrispinator
Jul 17, 2010 03:38 PM
fordbeast_80
Dec 28, 2009 12:32 PM
Stangfire
Oct 9, 2003 04:23 PM
