Loose Steering
Old Dec 28, 2009 | 11:47 AM
fordbeast_80's Avatar
fordbeast_80
Loose Steering
Hey yall, my brother just picked up an 1981 f100, and the steering is loose, I am used to working on 60-70s truck s so I looked at ti for him expecting to find a shot rag joint, but no rag inder the hood? just a knuckle, so my qeustion is how do you tighen up the steering in this year truck? it dont wander or track or pull like an alignment proplem just alot of play in the wheel it seems.
Old Dec 28, 2009 | 12:32 PM
ri_truck_guy's Avatar
ri_truck_guy
Unless you have an aftermarket steering shaft, there is a rag joint. It's under a plastic cover where the steering shaft connects to the steering box. Check that and all your steering gear (ball joints or king pins, tie rods, etc.) for wear. If all those check ok, you can adjust the steering load by losening the locknut located on the small slotted shaft on top of the steering box, and turning the shaft clockwise. You should not try to adjust that shaft more than a quarter of a turn at a time. This may provide some temporary relief for the loose steering, but will cause the box to wear even quicker. After a couple of adjustments you'll need to replace the box.
jmkelly
Sep 5, 2017 04:30 PM
Fish_Scientist
24
Jul 20, 2017 10:57 AM
78150custom
Dec 12, 2009 07:20 PM
FTWDEVIANT1
Offroad & 4x4
Feb 10, 2008 10:32 AM
rusty68
Nov 27, 2001 03:29 PM
