intercooler clamp part number
Old May 28, 2012 | 10:01 PM
Airzima's Avatar
Airzima
My intercooler to turbo clamp blew off 3 times in 30 miles today when i was towing 17000 lb trailer at 9000 k of altitude. I had this clamp off 3 months ago when i changed the fanbelt. I had a standard hose clamp of right right dimension It got me through the last 120 miles without a problem. Does anyone have the factory number for a replacement hose clamp. There is a NAPAs store in thios small town, so maybe they have something that will be better than the hose clamp than I am using.l
Old May 28, 2012 | 10:15 PM
m-chan68's Avatar
m-chan68
Part numbers for CAC hose clamps from Ford are as follows:
6C3Z-6K786-EA
6C2Z-6K786-AA
1C3Z-6K786-CA
6C2Z-6K786-BA
HOPE THIS HELPS.
Old May 28, 2012 | 10:20 PM
Piolet's Avatar
Piolet
Riffraff Diesel: T-Bolt Boot Clamps
If I remember the dealership only sells them with the boots or the pipe. I could be wrong.
I don't have the part numbers for Ford, but RiffRaff will be able to help you.
Old May 28, 2012 | 10:29 PM
bismic's Avatar
bismic
This is what I have written down (been awhile since I documented, so I am not 100% sure on it - especially since I have only 3 sizes and Mike lists 4 part numbers).
Hot side:
Two - 2.75", One - 3.25", One - 3.5"
Cold side:
Four - 3.25"
Mike - do you have the sizes of the part numbers you listed (no hurry since I am already imposing on you for quite a few other things!!!!)?
Old May 28, 2012 | 10:37 PM
m-chan68's Avatar
m-chan68
Hot side:
Cold side:
Four - 3.25"
I obtained those numbers from HvBOM off a random VIN for a 2004 truck I copied off Ebay.
Those four are what it lists, and calls for one of each with the exception of the last one, which it calls for two of (6C2Z-6K786-BA). As far as sizes, I couldn't tell you since it doesn't list it. I am ASSUMING (and you know what happens when you assume right?) the last number is for the clamp on the charge air cooler itself, since it calls for two of them.
Old May 29, 2012 | 08:58 AM
Airzima's Avatar
Airzima
Thank you all for the information. I found a Ford dealerabout 30 miles south of here and I will call them later today to see if they have any in stock. But first things first, I am going to park the trailer up on the mountain and go for a ride in the polaris RZR. I will not have interent access, so again thank you for the input
67 FE Fan
Nov 14, 2014 04:44 PM
canister
Jan 23, 2010 07:27 PM
Hotwheelbill
May 6, 2009 10:19 AM
loopsy
Apr 21, 2009 09:37 AM
joe blow
Mar 18, 2009 01:55 PM
