Part number for boots
Old Apr 20, 2009 | 10:57 PM
loopsy's Avatar
loopsy
I have boots that appear cracked and would like to replace them. What are the part number for those. Can they be bought with an International part number. And who else might sell these other than the dealership. Would a regular high pressure/heat resistant hose work?
Thanks
2004, crew, FX4, LB, 76,000k
Fumoto, zoodad, MBRP 4" Turbo Back
Old Apr 21, 2009 | 02:28 AM
cartmanea's Avatar
cartmanea
The one on the turbo is a Ford-only part I think because of the angle, the rest you just have to order the right size, try intakehoses.com
Old Apr 21, 2009 | 05:09 AM
bismic's Avatar
bismic
This may or may not interest you:
http://www.dieselsite.com/index.asp?...ROD&ProdID=804
or
SILICONE HOSE,SILICONE HOSES,TURBO HOSE,TURBO HOSES,INTERCOOLER HOSE
Also - (compliments of PowerstrokeHD in July of 2008)
Intercooler Hose Blow-Off; Oil Leaks at Intercooler Hoses:
Some trucks may exhibit oil leakage from the hot side intercooler hoses. If one of the hot side intercooler hoses blow off it will cause the truck to exhibit a low power/low boost condition. Hot side intercooler tubes are no longer available as an assembly. Replacement hoses have a revised inner liner that has adhesive properties. Use the following parts as needed to service the condition:
Short upper hose, equal length elbow: 6C3Z-6C640-C; metal tube: single alternator 6C3Z-6K769-B or dual alternator 6C3Z-6K769-A.
Long upper hose, unequal length elbow: 6C3Z-6C640-A; metal tube: single alternator 5C3Z-6K769-AA or dual alternator 5C3Z-6K769-BA.
Use this hose and tube combination if the hose blows off
Clamps: upper hose 6C2Z-6K786-AA; lower hose to tube 6C3Z-6K786-CA; lower hose to intercooler 6C3Z-6K786-EA.
Lower hose, all: 6C3Z-6C640-B.
Clean the hose mating surfaces to ensure the hoses will stay in place. Seat the hoses completely onto their mounting surfaces before tightening the clamps to 9 ft/lbs. Undamaged hoses may be reused, but they must be cleaned and inspected. If the inside of the hose is blue, it is recommended to apply a thin uniform coating of Motorcraft TA-31 RTV silicone to the mounting surface after cleaning. After reeassembling, allow the silicone to cure for three hours before driving the truck. Test drive the truck while monitoring the boost pressures, which should be 22-25 PSI. An overboost condition will cause the hose to blow off.
TSB 07-5-15.
On 2004/05 trucks that exhibit the cold side hose/pipe blowing off at the intake manifold, replace the plastic tube with part #6C3Z-6C640-AA as in recall 05B29 (trucks built from 12-15-03 to 4-1-04), or repair as in TSB # 05-22-3 (trucks built from 4-1-05). Clean the intercooler and intake flange with brake parts cleaner. Seat the hose/pipe onto the intake manifold and torque the clamp to 9 ft/lbs (12 NM). Broadcast Message 1329, TSB 04-20-9, TSB 05-22-3.
Also - when you install:
If you really want that hose to stay put, clean the hose and the pipe with some brakecleen, rough up the surfaces with some steel wool, and apply some permatex high-tack. Then put it back on, tighten clamp to 9 ft-lbs, and let it dry for a few hours.
Old Apr 21, 2009 | 09:37 AM
loopsy's Avatar
loopsy
Thanks this helps.
edgar1960
Aug 23, 2013 05:35 AM
1L243
Jul 13, 2012 06:43 PM
Doc Feel Good
Oct 6, 2011 12:47 PM
Speedracer302
Aug 10, 2011 04:09 PM
custom_nirvana
Jun 7, 2008 07:28 PM
