Coolant leak again
Old May 28, 2012 | 08:10 PM
dmanshane's Avatar
dmanshane
Coolant leak again
Ok I had this problem a couple weeks ago I replaced the heater core even though the heater box was dry and dusty but on passenger side the plastic panel on floor that snaps on its level full with antifreeze and dripping out the bottom of cab heater box is still dry and carpet around fire wall dry what is going on ???? Help
Old May 28, 2012 | 08:24 PM
Bonanza35's Avatar
Bonanza35
I couldn't really tell you except to start over and due again. It has to be leaking somewhere there or you wouldn't have coolant. Maybe a bad heater core, or you got a screw in it.
Chet
Old May 28, 2012 | 09:59 PM
dmanshane's Avatar
dmanshane
But you pull the cover off the heater box and it's dry it makes no sense what so ever to me if it would be the heater core the inside of the box under the heater core would be wet right
Old May 28, 2012 | 10:43 PM
Bonanza35's Avatar
Bonanza35
You would think so. But there's know other place it could come from.
Chet
Old May 29, 2012 | 06:24 AM
dmanshane's Avatar
dmanshane
The only think I can think of is one o the heater hoses where it hooks to the core is leaking and makin it all weird?
Old Dec 28, 2012 | 06:24 PM
dmanshane's Avatar
dmanshane
well i feel like a retard i found my coolant leak the other day... well where it came from because it jsut stopped leaking all of the sudden... i had a 1 gallon jug of antifreeze behind the back seat.. had a pin hole in it.... nice
Old Dec 28, 2012 | 06:36 PM
BJsCOOT2's Avatar
BJsCOOT2
Sounds like something I would pull
Old Dec 28, 2012 | 09:09 PM
crop harvester's Avatar
crop harvester
well, least it was a easy fix.
Old Dec 28, 2012 | 09:27 PM
dmanshane's Avatar
dmanshane
It was expensive I Replaced the heater core then took to a repair shop I was mad
blue92f150
Apr 14, 2009 06:31 PM
1957F100
Jan 7, 2008 10:27 AM
slychicken37
Nov 19, 2006 08:01 PM
dropped74
Jan 12, 2006 11:09 AM
smoke n tires
Oct 19, 2004 06:49 AM
