Changing Heater Core
Old Sep 14, 2007 | 07:12 PM
1957F100's Avatar
1957F100
Im just gettting ready to replace my heater core since its starting to get colder in the morning and im going to need it pretty soon for my drives to work. Before i start i was just wondering how i get to the heater core...do i access it from the engine compartment or is it in the cab by the glove box?
i think i have everything pretty much covered but my other question is how much coolant do i have to buy since im going to have to drain it out? and ive also heard something about adding something to the coolant...can somebody please clear things up for me?
Old Sep 14, 2007 | 08:20 PM
Dave Sponaugle's Avatar
Dave Sponaugle
4 gallons of antifreeze
4 gallons of distilled water
2 pints of DCA 4
Another alternative is heavy duty diesel antifreeze which has the SCA (DCA 4) premixed into the antifreeze.
I am running Fleet Charge premixed in mine.
The antifreeze is purple.
As for changing the heater core,
Drain the coolant and remove the hoses from the heater core in the engine compartment.
Then I take the glove box out and then open the heater up on my 86.
About a 40 minute job.
But I think the 94 may be a bit more involved since the dash is different.
Old Sep 15, 2007 | 08:39 AM
PLC7.3's Avatar
PLC7.3
Glove box remove, then find all the screws holding the heater core cover on, there are 7...... make sure you use the foam piece(s) you find. When installing the new heater core ensure the tubes are sealed from the engine side at the firewall.... any leaks at the hose connections has a nasty habit of leaking inside the cab/heater box..... don't ask how I know. Now if your changing the core because of lack of heat in the winter there is a little adjustment available on the blend door cable.......look in and up through the glove box opening. You should see a red barrel with grooves and a white locking devise, this adjusts the amount of rotation of the **** for heat/cold selection.. you may have done this before.
Old Sep 15, 2007 | 09:08 AM
1957F100's Avatar
1957F100
im replacing the heater core because it blew in the beggining of the summer...and since i knew i wouldnt be using it i just bypassed it. but since its starting to get colder in the mornings im going to need it pretty soon so im finally getting around to replacing it.
ive figured out how to get to it...and ive replaced a few before so i know how to do it...can somebody give me some more info on the coolant thing and the additive...im not really sure i know what i need right now.
Old Jan 7, 2008 | 10:07 AM
86 F-250 Diesel 4X4's Avatar
86 F-250 Diesel 4X4
Heater Core Change
Found this from another thread awhile back. Can I just drain the fluid from the radiator and then replace with the fluid I drained when I'm done??
2 pints of DCA 4
Do I need any sealant or anything else in addition to the core??
Mike
Old Jan 7, 2008 | 10:27 AM
PLC7.3's Avatar
PLC7.3
Save the foam pieces that seal the heater top..... seal the holes where the heater tubes go through firewall so any coolant leaks at the hoses(should there be any) can't get into the cab.
