heater core???
Old Oct 17, 2004 | 12:30 AM
smoke n tires's Avatar
smoke n tires
heater core???
i have a 78 f150 with a 460 and AC. it has the heater box under the hood. the other day i was driving and smelt coolant, its was dripping down on the floor. as i got closer to home the temp gauge shot up and i heard a hissing. when i opened the hood i saw i blew a heater hose so i let it cool and fixed it. when i filled it with coolant again i started it and turned the heat on. no leaks and it ran cool how it should. i cant figure out how the coolant got in the heater duct if the core seems to be fine still............anyone???????
Old Oct 17, 2004 | 07:49 PM
hdgapeach's Avatar
hdgapeach
If the coolant sprayed toward the box the steam/liquid shower could have penetrated the seam/seal enough to get into the box and cause the drip in the cab. Seen it before on one that blew near the clamp on the heater core end.
Old Oct 18, 2004 | 10:03 PM
smoke n tires
your problably right, it didnt leak again today, and its very rare that the core and the line would blow at the same time. i replaced all the hoses and its seems to be fine.
Old Oct 19, 2004 | 06:49 AM
victorcharlie's Avatar
victorcharlie
I had a similar problem on my 84 last year. If you haven't replaced the heater core on your 78, you might want to think about it. Mine wouldn't leak until I wound the engine up, but then it would fog the window. Heater cores are cheap, and not to time consuming to replace.
wisdum
34
Jun 8, 2022 03:05 AM
tweak1029
Mar 28, 2016 02:27 PM
jrg24
1983 - 2012 Ranger & B-Series
Jan 12, 2014 07:06 AM
Rob Cuenin
17
Mar 10, 2013 11:47 AM
Bruin008
Jan 19, 2013 01:37 PM
