Crutchfield is saying if you have factory NAV and subwoofer this works (there is the option to delete this vehicle and change your year/model/factory radio to see what fits): Car Selector Infinity Reference X REF-8602cfx Great for any power supply You can power these speakers with up to 60 watts of RMS power — they'll work great with an external amplifier, but they're also sensitive enough to be a good match for a factory or aftermarket stereo. Plus, Infinity comes up with a safe way to get a little more power out of your system — these 3-ohm speakers combine with the speaker wire in your car so your car stereo sees actual 4-ohm impedance. ((True Four Ohm Impedance technology: speaker's 3-ohm impedance combines with speaker wire impedance for a 4-ohm load))Grilles are not included — factory grilles are appropriate for most installations.
Special $130 for first set $65 for the second Double the speakers, not the price
Buy one pair of Infinity Reference Xspeakers or a component speaker set, and get a second, of equal or lesser value, for half price.
"Just add the qualifying Infinity gear to your cart. We'll automatically apply the 50% instant savings to the qualifying item on your order. <!--If you add a second qualifying speaker option, we'll automatically increase your discount.--> Offer ends 6/23/2012. We retain the right to cancel and/or modify this offer at any time without prior notice. Return of qualifying item will void the offer and will require an adjustment of the refund amount to reflect the discount given."
However they seem to be saying that they will not fit in the back, indicating that those are 5.25 speakers. Folks seemed to do fine with the 6x8 predecessor to this 6x8 Infininty, but also sounded like they had speakers in rear doors, not in the side panel next to the rear seat.
I'm a Polk guy. Their tweeters are amazing, I will get you some pics. Takes a little work with a pocket knife to install them, just make the factory tweeter hole 1" in diameter rather than the 7/8" that the factory tweets are.
The lower mid sound is not great which is why I'm also a kicker fan. I've got two 10" subs behind my seats!
I just pulled my side panel behind the rear seat. It is the same 6x8 speaker that is in the front doors. Unless the Infinity is way deeper, it should fit.
Originally Posted by Tuxedo Scorpion
so they give us a discount on speakers we cant use. brilliant.
