Leveling Kit Question
Old May 27, 2012 | 10:41 PM
LemonHeadTyler's Avatar
LemonHeadTyler
I am looking at raising my 95 f150's front end up a couple of inches to make my truck sit level. I am not looking to spend hundreds of dollars to do this. What would be the best way to raise up the front of my truck? I would like to raise it 3-5 inches. Thanks.
Old May 28, 2012 | 12:32 AM
Midnite1987's Avatar
Midnite1987
Raising it 2" will bring you about level.
There's 3 options.
Get a set of moog 844 springs (2wd f250 coils)
Order a set of leveling springs
Or get a set of 2" spring spacers. This it the route I went. Gor mine on eBay bout $80 I think
Old May 28, 2012 | 12:33 AM
Midnite1987
Also if you try the search above there have been many threads on leveling these trucks
Old May 28, 2012 | 08:46 AM
TexasGuy001's Avatar
TexasGuy001
I have Superlift leveling springs. The number should be 117.
Old May 28, 2012 | 09:40 AM
LemonHeadTyler
Appreciate it. So if I just get the springs they are the only thing I need to replace on the suspension system?
Old May 28, 2012 | 10:07 AM
raptor1971's Avatar
raptor1971
It will cost some money to do the lift. I had the spacers before I put the 6" lift kit on.I should of used coil springs instead, but it up to you what to use.
You will also need to get a alignment and alignment bushings.
you could get these adjustable alignment bushings and install them so the alignment shop will not charge you to install them. They will just have to adjust them
Adjustable Alignment Bushings Pair
or get the kit with springs and adjustable alignment bushings.
BDS 1.5" - 2" Leveling Kit
Note these are for 4x4, they have others for 2wd since I do not know what you have.
Make sure you tell the alignment shop that you lifted it and ask them if they can do the alignment right.
The first shop I took it to did it wrong and would not fix it. I emailed head office and they got another shop to do it right.
Also you do not have strut's. You have coil springs and shocks on the front.
Old May 28, 2012 | 10:53 AM
LemonHeadTyler
Thanks for the help raptor. That is exactly what I am looking for.
Old May 28, 2012 | 02:10 PM
Midnite1987
My spacers were $80
I ordered the adjustable camber bushings $60
And the allignment $400!!!!
The guy had a hell of a time with the adjustable bushings and had to adjust them 3-4times which is why it cost so much. They said I'd would have been the same price if i used their bushings, then I would have saved the $60 for the bushings..... But I'm also in Alberta and stuff like that seems more expensive here
Old May 28, 2012 | 09:04 PM
LemonHeadTyler
Yeah I can do the alignment and installation myself so it should not be to much.
mikeycars
May 21, 2016 02:43 PM
offroadcrazy304
Apr 5, 2012 07:42 PM
jmarblack
Jul 15, 2007 09:01 PM
oricle
Nov 28, 2005 05:14 PM
1987fi50
Nov 15, 2005 05:04 PM
