06 E250 pausing air
Old May 27, 2012 | 08:57 AM
tps93ranger's Avatar
tps93ranger
06 E250 pausing air
I drive an 06 e250 with 99k on it for work and when I am driving around and the engine gets under any strain the air shuts off and when the engine returns to normal the air comes back on. I have filled and charged the freon cause I was told maybe it was low, no change.Hope someone has an idea of what I can do to fix this.
Old May 30, 2012 | 05:58 AM
JWA's Avatar
JWA
You have issues with the vacuum control system---possibly a leaking servo somewhere, cracked hose or any number of other things. Your worst case scenario is the reservoir having developed a leak---they're very difficult to replace, or so I've heard.
Look for a heater control system vacuum diagram and start checking it out--doesn't sound to bad at all.
Old May 30, 2012 | 08:42 PM
2000Ford2000's Avatar
2000Ford2000
and then check the charge as you probably overcharged it and that will make it worse.
Isn't the air actually reverting to the defrosters when this happens rather than shutting off?
Old May 31, 2012 | 04:46 AM
JWA's Avatar
JWA
This is probably what's happening-----93Ranger might be describing it differently.
More than likely the charge is incorrect now too----both somewhat easy to fix.
Old Jul 5, 2012 | 02:23 PM
tps93ranger
It is reverting to the defrost and the floor vents so I will check my charge again and see if that is my problem. I spent an hour one day looking for a vacuum leak and could not find one anywhere. Thanx for the info as it is hot as hell here in TN. and it shuts down constantly.
jacecil082
Apr 22, 2018 10:06 AM
daveya48187
Escape & Escape Hybrid
May 11, 2013 06:40 AM
LOWRPM
Aug 12, 2006 12:30 PM
phish555
Jun 8, 2006 10:32 PM
kw5413
Jul 25, 2005 10:49 PM
