Painted Drive Shaft
Old May 26, 2012 | 06:25 AM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
Painted Drive Shaft
Anyone paint their drive shaft or propeller shaft? Thinkin about a very light coat of rattle can primer, nothin heavy or balance changing. Thoughts?
Old May 26, 2012 | 07:09 AM
Hdslider's Avatar
Hdslider
I have always painted everything the factory didn't. Never a problem.
Old May 26, 2012 | 07:11 AM
Tuxedo Scorpion
on vehicle or off
edit: and when you say everything, does that include steering knuckle / joint? cause i dont see a way to paint that without removal
Old May 26, 2012 | 07:37 AM
Hdslider's Avatar
Hdslider
Yes I paint all that stuff on the truck. You can purty Much get to everything. I hold prices of cardboard behind some items as not to paint stuff that don't need to be.
Old May 26, 2012 | 07:40 AM
darren32's Avatar
darren32
Just curious why you would want to paint an aluminum drive shaft Tuxer? I think it's fine as is. Maybe polish it if it was a show truck (that would look really cool!)
Or are you talking about the front DS?
Thanks
Old May 26, 2012 | 07:59 AM
Tuxedo Scorpion
Its not alum. Its steel.
Old May 26, 2012 | 08:09 AM
darren32's Avatar
darren32
Really? Mine is aluminum, just assumed they all were. OK, now you makin' some sense.
Thanks
Old May 26, 2012 | 08:20 AM
urzu007's Avatar
urzu007
I painted the first year and the first Northern NY winter removed all the paint. So I ended up saying the heck with it and tried the bed liner in a car stuff on it. It has been about a year and a half it stayed on after the winter and no problems yet. I did try my best to make sure the coating was as even as I could get it. Most mechanics I talked to about it said that it would be no big deal.
Old May 26, 2012 | 08:27 AM
Tuxedo Scorpion
Ive heard of aluminium drive shafts and hoods but never seen em
Old May 26, 2012 | 09:06 AM
Tuxedo Scorpion
Thanks
that doesnt look like aluminum to me. that looks like steel buddy. go put a magnet on it.
Old May 26, 2012 | 09:12 AM
darren32's Avatar
darren32
I used to weld aluminum for a living so I am not gonna argue this one. Call it whatever you like, it's aluminum.
Thanks
Old May 26, 2012 | 09:19 AM
Tuxedo Scorpion
i weld too. and my driveshaft is ferrous. magnet sticks. magnet stick to yours?
Old May 26, 2012 | 09:21 AM
Andrew010's Avatar
Andrew010
Thanks
He's got one of those goofy extra long trucks that require a 2 piece drive shaft, which is made of heavier steel.....
Old May 26, 2012 | 09:24 AM
Tuxedo Scorpion
its not two piece. and how could it be "heavier" steel if the short ones are supposedly not even steel to begin with.
Old May 26, 2012 | 09:28 AM
Andrew010's Avatar
Andrew010
I thought all LB truck had 2 piece drive shaft. Maybe it's a 250 vs 350 thing....
I meant the steel was heavier than aluminum.
