94 4.0 bogging under throttle
Old May 30, 2012 | 10:31 AM
JoeNoble's Avatar
JoeNoble
Meant its possible that it wasn't disconnected long enough
Old May 30, 2012 | 10:42 AM
pawpaw's Avatar
pawpaw
Originally Posted by JoeNoble
Yes I did disconnect the batter but it's possible that it was for long enough, not familiar with the relearn procedure, after the disconnect and yes unfortunately it's an auto.
If you had the battery disconnected while doing the repairs, or a door was open, under hood, or cabin light on, ect, that electrical load will wipe the KAM fast. Normally with no electrical loads on, it'll take maybe 15 min to wipe the KAM.
Here is a link on how to do the cold & warm idle relearn routine.
Ford Truck Enthusiasts Forums - View Single Post - high idle problem
OK, so you have an auto tranny, so you might have more than one problem causing the bogging at throttle up. Have you been having tranny shifting problems???
Old May 30, 2012 | 11:14 AM
JoeNoble's Avatar
JoeNoble
It was shifting a lil funny the other day but I just figured it was because of the lack of power and the fact that I kept having to put the pedal all the way to the floor. Let me disconnect the battery again, do the relearn precess and retest the fuel pressure and I'll let ya know what I find. Thanks for all the help!
Old May 30, 2012 | 12:24 PM
pawpaw's Avatar
pawpaw
OK, so did you do the code scan Before, or After the battery disconnect/KAM wipe?????
Old May 30, 2012 | 12:26 PM
JoeNoble's Avatar
JoeNoble
I did it after but like I said I didn't have it disconnected long. When I get off work I'm gonna do it all again.
Old May 30, 2012 | 01:08 PM
pawpaw's Avatar
pawpaw
If you scanned for trouble codes After the battery disconnect, that also wiped any stored codes in KAM, so you'll need to drive it some & see if any codes reset & if they do the CEL will turn on. Then scan it again & post All code Numbers found.
The cold & warm idle relearn may help with any idle, or off throttle operation & wiping the corrupt fuel trim tables so the computer can begin to rebuild new ones after the repair, might help with the bog problem.
If the tranny is still having shift problems, maybe it'll set some more codes that'll help with that diagnosis.
Old May 30, 2012 | 09:50 PM
JoeNoble's Avatar
JoeNoble
Ok so disconnected the B- for about 20 mins then went through the relearn process and the checked fuel pressure again. The I took her for a short test drive. She seemed to run much better but then she did the same thing after I installed the FPR so I guess we'll see. Now the fuel pressure was still right at 30psi and when I give it a rev it pops up to 40. Also it does idle a lil rough sometimes then it'll be fine again. Which I suppose could be because the plugs that are in it are probably black from when she was bogging bad. The 59 code is still showing up so maybe instead of a fuel pump I should buy a Trans filter and some fluid? And is 30 psi too low? Thanks again joe
Old May 31, 2012 | 05:56 AM
pawpaw's Avatar
pawpaw
On the fuel pressure test, review post #6. Was this last reading with it jumping to 40 psi when you rev the engine, with the new FPR????
If you suspect the plugs are fouled, pick one thats easy to get at, remove & inspect/clean it/them & see how the bog & rough idle goes.
Also review post #10 for other possibilities, like a clogged air filter, or air intake tube to the air box. Critters like to build nests in there, so make sure its clear all the way from the air box to the wheel well.
What happens if you drive it with the OD off????
Old May 31, 2012 | 09:00 AM
JoeNoble's Avatar
JoeNoble
Yeah that was with the new fpr. There was actually a crack in the stock air tube so I had to make a new intake so that's definitely not clogged. Hadn't really thought about trying her with OD off.
Old May 31, 2012 | 09:01 AM
JoeNoble's Avatar
JoeNoble
Also I may try the relearn process again just to make sure it took and that I did it right.
Old May 31, 2012 | 09:32 AM
pawpaw's Avatar
pawpaw
Well I see you've modified & done away with the factory cold air intake. Where did you locate the IAT sensor???? That rig you have on there now is sucking in plenty of Hot under hood air, not a good thing for a smooth running engine!!!!
What other mods have you done that we don't know about?????
Old May 31, 2012 | 10:23 AM
JoeNoble's Avatar
JoeNoble
Didnt really have a choice as it was sucking in in metered air. Was the IAT on the actual air box? The only thing I actually removed was the hose an mechanism that lets hot air off the exhaust mani into the intake. That's the only "mod". So I rescanned the codes after taking her for a quick drive and here's what I got.
http://i69.photobucket.com/albums/i5...f/197a5108.mp4
Old May 31, 2012 | 10:29 AM
  #28
JoeNoble's Avatar
JoeNoble
After watching the vid I'm seeing 59, 565 and 566. Is that right?
Old May 31, 2012 | 11:57 AM
  #29
JoeNoble's Avatar
JoeNoble
Here's a better link. OBD1 codes on my ranger - YouTube
Old May 31, 2012 | 05:44 PM
  #30
JoeNoble's Avatar
JoeNoble
Ok so I replaced the purge valve solenoid but that code is still showing up and there are more now. OBD1 codes - YouTube
