radiator support fitment question
Old May 25, 2012 | 02:12 AM
86pullerf350's Avatar
86pullerf350
Question radiator support fitment question
My 86 needs a new support and I have been searching for quite some time now and have not been able to find one. I was talking to my cousin tonight about it and he gave me the idea to see if a newer body style (87-97 with 460) support would work. Are all the fender mounting bolt holes the same? Will the grille, trim pieces, and light bezels bolt in place? Any suggestions are appreciated.
Thanks guys Bob
Old May 25, 2012 | 05:23 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Headlight mounting is different.
Rad itself is the same.
Old May 25, 2012 | 09:26 PM
86pullerf350
Dang, Thats what I was afraid of. Thanks Ard.
Do you know of anywhere that sells a good aftermarket support that will not rot out in 2-3 yrs. I would prefer a ford factory support if I can find one.
Old May 25, 2012 | 09:56 PM
LARIAT 85's Avatar
LARIAT 85
The correct radiator core support you need will only fit the 1985 - 1986 Ford F-150/250 and Broncos.
The one from 1980 - 1984 is different in that these years used a different style of radiator and mounting system. And like ArdWrknTrk said, the one from 1987 - 1991 won't work because the headlight mounting is different.
Old May 26, 2012 | 02:52 PM
Franklin2's Avatar
Franklin2
This place says they have one;
1986
Rad/Core Support
Ford Truck F250 FD22188 NOF $Call Jean Guy's Used Cars and Parts Inc. USA-NH(Pelham) E-mail (Outside NH)1-800-535-7171 (NH)1-800-235-7171
Old May 27, 2012 | 11:14 AM
86pullerf350
Lariat, My truck is an f350 1 ton with 460.
Franklin, Thanks, I will give them a call on tuesday and get more details on what they have. The f250 and f350 would be the same if they both have the 460 in them?
Old May 27, 2012 | 02:21 PM
Diesel_Brad's Avatar
Diesel_Brad
Look at LMC.
As for not rotting in 2-3 years, a brand new OEm will rot out if not prepped right
Old May 27, 2012 | 03:40 PM
Franklin2's Avatar
Franklin2
The junkyard site listed 3 flavors:
1. The tall diesel support
2. The wide diesel support
3. All gas supports.
So according to them, any gas engine support will work, f150, f250. f350, and probably Bronco, so long as it is a 85 through 86 and has a gasoline engine.
Old May 27, 2012 | 08:26 PM
86pullerf350
Franklin, My cousin has an 83 f250 351w and the rad opening on his support is about 6-8" narrower. I would think that ford would have done this since the small block and 6cyl trucks wouldn't need such a big radiator.
I'm really kicking myself now because I had gotten an 86 f350 2wd diesel parts truck and didn't save the rad support or radiator. I could have made it work. I did save the bell housing, 4spd trans, and a few other parts that I needed. I got the truck mainly for the doors, fenders, and bed. Thats why its blue in my avatar. I paid $250 for it not running.
Old May 29, 2012 | 07:56 PM
86pullerf350
1986
Rad/Core Support
I called these guys today and they said they have the support for my truck for $150. He said that it has next to no rust on it and is in very good condition.
Old May 29, 2012 | 08:20 PM
Franklin2's Avatar
Franklin2
His truck is not a 85 or 86 correct? I don't know, I am just using the junkyard cross reference.
Old May 29, 2012 | 08:51 PM
86pullerf350
Franklin, Yes my cousins truck is an 83. The junkyard guy said he had a support for an 86 f250 with big block gas engine.
LeoJr
Jan 13, 2014 10:11 PM
ken_r_mer
Oct 18, 2011 07:09 AM
tude
Nov 1, 2005 05:01 AM
Redj
Jan 7, 2004 08:40 AM
ItzKwik
May 6, 2003 08:38 PM
