will f250 rear leafs bolt right up to f150 leaf mounts?
Old 05-24-2012, 08:29 PM
FordOwnerJoey's Avatar
FordOwnerJoey
FordOwnerJoey is offline
title pretty much says it all. I wanna know if I can get a set of 3/4 ton leaf springs to put on my 1/2 truck. I wanna be able to haul a little better with a load in the back. I know the frame, etc is still only 1/2 ton but i want better leafs.
will they bolt right in or is there different lengths between the 1/2 and 3/4 tons to where the mounts have to be moved?
Old 05-24-2012, 09:08 PM
ncranchero's Avatar
ncranchero
ncranchero is offline
AFIK they are bolt-on if you have a 4x4 with 3" leaf springs. The 4x2 will have 2.5" in springs. They should be the same length so you could knock the rivets off your 2.5" brackets and bolt on the 3" counterparts. I plan on doing the same thing and mine is 4x4 so it'll be an easy swap.
Old 05-24-2012, 09:27 PM
FordOwnerJoey
ok thanks, ive already replaced the leafs before so i know I can do it, I didnt replace the top leaf though, just took the "new" ones and put that pack right up agaisnt the top one of the old pack. Now im going to try to track down some f250 leafs, yes its 4x4 with 3in leafs.
Old 05-24-2012, 09:33 PM
Midnite1987's Avatar
Midnite1987
Midnite1987 is offline
My f150 had a 4 leaf pack. I found a 5 leaf pack out of a bronco at the JY an swapped it in. (someone already took the axle to the leafs were just 2 bolts to remove) I looked at the f250 leafs which the only ones that were there at the time were 5leaf set just like the bronco had anyways
Old 05-25-2012, 07:14 AM
FordOwnerJoey
Thats whatn i put on over a yr ago was a 5 leaf pack from an older bronco, i would think F250 springs would be thicker to allow for more weight..
Old 05-25-2012, 08:37 AM
garlindethfury's Avatar
garlindethfury
garlindethfury is offline
that is what that extra half and inch of width is for.
Old 05-25-2012, 09:01 AM
ncranchero's Avatar
ncranchero
That seems like the case. I have both sitting in the yard at my shop & I'll measure them and see.
Old 05-25-2012, 09:02 AM
FordOwnerJoey
Well I thought all 4x4s already had the 3 inch cuz thats what was on there before. and 2x4 has the 2 1/2 inch
Old 05-25-2012, 09:07 AM
ncranchero's Avatar
ncranchero
All I have seen.
Old 05-25-2012, 09:42 AM
SCRebel's Avatar
SCRebel
SCRebel is offline
That is correct. The springs must be thicker on the F250 springs, or have a sharper arch.
I know the F250 HD springs provide 3" higher in the rear, on F150 compared to stock F150 springs. I am wanting a set of F250 HD springs.
Old 05-25-2012, 12:00 PM
BigBlueOx's Avatar
BigBlueOx
BigBlueOx is offline
^Yup^. I put F-250 HD springs in the back of my 150 and it lifted it 3".
Old 05-25-2012, 12:05 PM
ncranchero's Avatar
ncranchero
My F150 4x4 springs are 3"/4-leaf/all .300 thick.
The F250 4x4 springs are 3"/5-leaf/.350 thick except the bottom leaf which is .400
Old 06-21-2012, 06:18 AM
jimmy wade's Avatar
jimmy wade
jimmy wade is offline
Could you please tell me what the weight rating is on your springs? it's stamped on the springs on the bottom leaf in front of the axle. I went to order new hd f250 springs and there were actually 2 different hd spring sets, 2810 lbs and one rated at 2975lbs. any help would be greatly appreciated!!!!
Jacob2
06-01-2019 01:51 PM
tobra
08-16-2014 09:31 PM
f2501967
05-20-2007 11:13 AM
RangerTuff05
10-12-2005 04:00 PM
the_webers_inc
06-26-2005 07:29 PM
Quick Reply: will f250 rear leafs bolt right up to f150 leaf mounts?
