Sponsored by: Auxito
Engine noise - Could be berring?
Old May 5, 2003 | 10:31 AM
damian's Avatar
damian
I am getting a low knocking / rattling noise under load that seems to be coming from the lower engine area. I think it sounds like a berring (280,000 KM on 97 f-150 4.6 by the way). Could it also be the slap or marbling I have read aboud here on the forum or is that a different sound.
If it is a berring, what are these engines like to work on? I have not done work on this truck before.
I am also getting a squeek whil driving from somewhere underneath that I think might be a u-joint. It goes squeek squeek squeek and only when accellerating and it varries with speed. What do you think?
Old May 5, 2003 | 08:41 PM
Racerguy's Avatar
Racerguy
A low dull knock under load is quite often bearings
I think I would start by hooking up a mechanic oil pressure gauge and see what you have for pressure.
The engine isnt really easy to work on. Make sure you have a good manual if you are going to try it. You'll also need some special tools for setting the cam timing.
The squeeking does sound like a U-joint.
I replace one in a truck like your's today. It only squeeked in reverse.
HKusp
Feb 29, 2008 10:48 PM
cmyers7
2004 - 2008 F150
Jun 24, 2007 12:49 PM
technoman26
May 3, 2006 06:10 AM
dblakney
May 18, 2004 08:28 PM
bierstadt
Sep 25, 2003 08:54 AM
