What's the plug??
Old May 23, 2012 | 09:41 PM
kev78's Avatar
kev78
What's the plug??
Hey everyone gotta question for ya, my buddy stopped the other day with his truck(2005 f350 lariat 6.0 auto) and told me when he was cleaning his bat terminals there was a wire unplugged with nothing around to plug it back into. It's along pass fender between vacuum pump and the battery. I looked on my 05 Ex and have the same plug but mine has a jumper plugged into it. Question is what is this plug for and will it hurt anything to be open or should I try make a jumper like my Ex has?
Old May 23, 2012 | 10:26 PM
m-chan68's Avatar
m-chan68
What you describe, is the connector that would plug into a harness for the secondary alternator on a factory dual alternator equipped truck, and a jumper on non dual alternator trucks such as your Excursion.
Old May 23, 2012 | 10:33 PM
kev78's Avatar
kev78
Ok, so on a single alt truck i should make a jumper for it. Would it be not charging now without the jumper??
Old May 23, 2012 | 10:54 PM
m-chan68's Avatar
m-chan68
That would be the light green with red stripe wire that cancels out the battery indicator warning light on the instrument cluster the moment the vehicle is started and charging system function is detected, from what I'm reading on the wiring diagram, it SHOULD still be charging without the jumper installed, but likely illuminating the battery warning indicator falsely.
borffmann
Dec 1, 2019 04:57 PM
mjmurdaugh
Modular V10 (6.8l)
Feb 13, 2018 04:19 PM
bradleyj
Electrical Systems/Wiring
Dec 11, 2005 08:18 PM
lpmorgan
Sep 25, 2005 07:47 PM
tbenton
Mar 10, 2004 10:12 AM
