04 ranger brake bleeding help
Old May 23, 2012 | 09:56 AM
fordbroncodave's Avatar
fordbroncodave
2004 ford ranger xlt 5 speed and 4.0 engine with 4X4 extended cab
I am helping a buddy bleed the brakes on this truck after installing both front loaded calipers. there is absolutely no air in the lines on all 4 bleeder screws but the brake pedal still goes to the floor with no resistance.
with the truck off the pedal becomes firm instantly but once the truck is started there is no pedal at all and goes to the floor.
is there another way to purge the system or something computer based that needs to be done?
help please
Old May 23, 2012 | 05:46 PM
pawpaw's Avatar
pawpaw
Have you bench bled the brake master cylinder????
Old May 23, 2012 | 08:25 PM
fordbroncodave
I didn't think I had to considering the fluid never got bellow 1/2 while changing calipers.
I read something on the mitchell program that i should loosen the sensor on the front of the master cylinder as well as disconnect both lines on the side and route them into the top of the master cylinder and continuosly pump the brakes.
also noticed the front calipers are locked so tight there is no way the truck can even move now
laxb51
Jul 2, 2010 04:01 PM
Lobo33
Feb 8, 2009 02:58 PM
951500
Nov 5, 2008 07:09 AM
xfordtech
Dec 2, 2005 04:26 AM
D_STICK
1978 - 1996 Big Bronco
Jul 14, 2001 01:01 AM
