Excessive play in steering wheel
Old May 22, 2012 | 11:16 PM
countryshiz87's Avatar
countryshiz87
i have a 1990 f250 4x4
I have replaced the steering gear and tightened it lightly and there is still way too much play in the steering wheel.
the problem seems to be in between the steering wheel and the gear box but i cant pinpoint it. Has anyone else come across this before because it is really difficult to offroad with. thanks
Old May 22, 2012 | 11:54 PM
metriccar's Avatar
metriccar
Probably the rubber coupling found on the steering column between the gearbox and firewall.
Old May 22, 2012 | 11:57 PM
85e150's Avatar
85e150
That joint and every other joint in the linkage is suspect. Have someone wiggle the wheel while you watch each link.
Old May 23, 2012 | 06:31 AM
tjc transport's Avatar
tjc transport
i ain't rite
with the engine off, have someone wiggle the steering wheel side to side while you look at the steering shaft. there is a teflon bushing between the upper shaft and the lower shaft. if the spring steel shim that holds it in breaks, the bushing will fall out, or work it's way up into the upper shaft and you end up with around 1/4 turn play in the steering column.
you cannot buy the bushing or retainer clip.
it can be rebuilt, but is a real pain to do. i can do it now in about 2 hours. it is really easier to just replace the steering column.
Old May 23, 2012 | 07:14 AM
XLT89F350cc's Avatar
XLT89F350cc
JY's should have a better steering shaft, firewall to box with a rag joint. W/O a rag joint, u feel every crack in the road, every pebble, its way too much. Ask me how i know
Old May 25, 2012 | 12:14 AM
countryshiz87
ok thanks for the input i think ill just get a new steering shaft. this may be a stupid question but whats JY's
Old May 25, 2012 | 12:19 AM
85e150's Avatar
85e150
"J unk Y ard", many times a source for like-new parts....
Old May 25, 2012 | 07:45 AM
rla2005's Avatar
rla2005
Would you trust your safety/life on a used junk yard part like a steering shaft? Not me....
Junkyards have their place, but not on a piece like this IMHO.
Old May 25, 2012 | 09:15 AM
tjc transport
i ain't rite
would you rather pay $1000+ for a new part from a dealer, or $100 for a just as good used part from a recycler?
Old May 25, 2012 | 10:59 AM
88dually's Avatar
88dually
If theres no play in the shaft, why not ? I have 2 shafts from jy's in my DD an prroject truck with no problems with tracking stright an no play at 70 on highways.
Old May 25, 2012 | 11:05 AM
metriccar's Avatar
metriccar
if you can tell the one in the junkyard is any better? Truck is not on the ground and may have steering lock on with same age and likely as many miles as your truck
Old May 25, 2012 | 12:10 PM
88dually's Avatar
88dually
At the jy, grab both ends an try to twist in opposite directions. If theres play, give. It back, if theres no play, bring it home
Old May 25, 2012 | 11:12 PM
Midnite1987's Avatar
Midnite1987
Got lookin at my steerin linkage and I thought my steering box was going but turns out its the slide shaft between the steering box and the ujoint under the dash.
Anyone suggest a place online to get one that will shop to Canada? Or what the part is atually called of I go to the part store?
Old May 26, 2012 | 01:48 AM
88dually's Avatar
88dually
Midnite, parts stores dont carry steering shaft, dealer or jy. You dont have any jy's near u ?
Old May 26, 2012 | 02:38 AM
Midnite1987
Yeah I'll go back there in the morning. Thought that might not be a bad thing to get a new one. But back to the JY I go in the morning
EBTDM
Escape & Escape Hybrid
Dec 13, 2017 08:35 AM
Whitey Ford
Mar 19, 2016 10:20 AM
ech0sh4y
40
Mar 17, 2008 07:45 PM
no_smoking2003
1997 - 2003 F150
Dec 31, 2004 03:57 PM
AbramsM1
Aug 19, 2004 10:57 AM
