Isspro gauge issue?
Old May 22, 2012 | 05:58 PM
joeyd61's Avatar
joeyd61
Isspro gauge issue?
My isspro EV2 preformax coolant temp gauge has been acting up, its sporadic, sometimes it works properly,sometimes it bounces between 150-230..almost acting like air in the system at times..Is the gauge/sending unit going bad?IF so which one??
I have lost a little coolant appx 1/4 gallon,I believe it was leaking from the small hose on the top of the radiator that goes to the right side of the reservoir, I guess the other question I have is, would the gauge act like this if cooling system is losing pressure/leaking??I wouldn't think so but it doesn't hurt to ask...
Old May 22, 2012 | 06:01 PM
CSIPSD's Avatar
CSIPSD
Check to make sure you have good contact at the connector at the back of the gauge, make sure the wires are completely seated in there. Also check the connector at the sender and make sure it is fully seated in the clip. I would pull the connector at the sensor and get some dielelectric grease in it.
Where is your sensor located? Water pump?
Old May 22, 2012 | 06:05 PM
joeyd61's Avatar
joeyd61
yes on the dr side of the pump.. I will check the connections on both ends and add the dielelectric grease tomorrow
Old May 22, 2012 | 06:18 PM
CSIPSD's Avatar
CSIPSD
The chances of a temp sender failure are very slim. I have lost one in 100k of driving.
Old May 23, 2012 | 05:05 PM
Michael_'s Avatar
Michael_
If you go to the ISSPRO website, then click "Support", then "Instructions", then scroll down to the bottom of the page you will see a file for EV2 troubleshooting. Definitely check the connection down at the sensor as mentioned above.
Old May 23, 2012 | 08:44 PM
clux's Avatar
clux
Ok I'll bite. Whats the dielectric grease going to do?
Old May 24, 2012 | 06:01 AM
Tugly's Avatar
Tugly
It aids in sealing the connector from water/contamination intrusion, it keeps the contacts from corroding, it's non-conductive, and it can help keep connector seals from drying out prematurely.
Old May 24, 2012 | 07:14 AM
clux's Avatar
clux
Ok, I'll restate my question.
What's dielectric grease going to do that will resolve this problem?
Old May 24, 2012 | 07:29 AM
joeyd61's Avatar
joeyd61
well,I don't know about the grease but all I have done is unplug and inspect the plugs in both ends.It has not "jumped" around yet but it was speratic to begin with.I will see in a few more weeks..
Old May 24, 2012 | 08:23 AM
CSIPSD's Avatar
CSIPSD
Water is the enemy of any electrical connection, dielectric grease is added to each and every connection I ever make on my truck...
While some of you run around with all kinds of electrical issues, I have not had one issue in 1,500,000 miles of driving.
With a bad or intermittent ground, the gauge will jump to max reading. If this is happening over and over it will give the appearance of the gauge jumping around.
Old May 24, 2012 | 09:16 AM
clux's Avatar
clux
I agree, dielectric grease is a great preventative measure. But putting it on after you have a problem is like putting a condom on after sex. It's too late for it to do what it's intended to do.
If the connection is corroded, it needs cleaned, and if that resolves the issue, by all means put some grease on.
Anthony Bauwens
Nov 8, 2016 08:39 AM
Hussler
Sep 27, 2013 05:57 PM
geearturi
Aerostar
Dec 9, 2012 01:30 AM
KenS999
Mar 17, 2008 03:58 PM
10-4 Crash
1983 - 2012 Ranger & B-Series
Feb 8, 2007 08:54 PM
