dually to SRW
Old May 22, 2012 | 04:20 PM
dutchford150's Avatar
dutchford150
dually to SRW
I see a lot of duallys on craigslist but not that many single rearwheel.
so now Iam thinking of buying a dually and converting it to srw.
now the question ? is it hard to do?? and what about the rear wheelwells?
grtz George
Old May 23, 2012 | 08:01 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
it's not hard to do,no.
for the front:
remove the DRW hubs,and simply bolt on the SRW D50 (f250) or D60 (srw f350) front hubs.
now you can bolt on your SRW front wheels.
for the rear:
(assuming your talking about "pickup" drw,since you mentioned wheel wells)
remove the rear axle,send the DRW pickup axle w/3:55's to me please.
and set in the SRW axle.
now your ready to install your SRW rear wheels.
for the bed,remove that too and install the SRW bed.
it's a weekend job for one average shade tree mechanic.
the DRW front hubs,6 DRW rims,the DRW rear axle,and the DRW bed are all worth good $,while all the SRW stuff you'll need,is all a dime a dozen.
you'll not only brake even,but end up a few hundred to the good (very possibly over 1k in your pocket with the DRW axle and bed being the biggest $ makers of course.)
Old May 23, 2012 | 10:00 PM
farmert's Avatar
farmert
for the front:
for the rear:
All this is true here in the States, but he is in Netherland, probably a different story to find parts there. Also you are assuming it is a 4X4, he may be looking at a 2wd.
Old May 24, 2012 | 08:46 PM
FORDF250HDXLT
oh that's right.a dually pickup pre- '99 will be a 2wd anyway.
forget the D50/D60 SRW front hub swap.the ones you'll be after will come from a SRW 2wd donor.
Truck Guy99
21
Jun 22, 2014 02:19 AM
TheOtherStyle
35
Aug 26, 2013 08:10 PM
FarmBoyF250
Aug 6, 2013 04:25 PM
300FOREVER
Mar 19, 2010 06:19 PM
Brown Falcon
Oct 19, 2008 05:35 PM
