SRW vs DRW
Old Aug 21, 2013 | 02:34 AM
TheOtherStyle's Avatar
TheOtherStyle
SRW vs DRW
Normally I'd do a search for what I'm looking for, but with everything for a single generation jumbled into a 3,000 page pile, it'd take me months of reading and browsing.
I'm about to come into possession of a 1987 F250, and its current config is 2wd SRW. I know the rear axle it has can run a DRW setup, but what about the front? What do I need to change to accommodate the dished wheels? Spindle, hub, ?
Thanks in advance while I sloooooooooooooowly work my way through 3,000 pages of everything 87-96.
Old Aug 21, 2013 | 03:12 AM
raystankewitz's Avatar
raystankewitz
Ya know, this comes up too often.
Your rear axle is not the same as a dually axle. Put a dually wheel on the rear and it will rub. A dually pickup axle is wider to accommodate the dually wheels.
And no, don't even think about cheeseball aluminum spacers from ebay.
Front hubs from a 2wd F350 will get the front but you need a 2wd or 4wd dually rear axle and not one from a chassis cab. That axle won't work right for you, either. Wrong width.
Here's a better thought - look around for a dually F350 to buy. It would be cheaper in the long run.
either that, or buy a (very expensive but done right) dually conversion kit from http://www.arrowcraft.com/products.php#kits Arrowcraft.
Just sayin'
Last edited by raystankewitz; Aug 21, 2013 at 03:16 AM. Reason: Added Arrowcraft information
Old Aug 21, 2013 | 07:44 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
there are a couple reasons (advantages imho) to convert the 250 to drw over buying a 350.
1.an f350 dually pickup only came as a 2wd truck pre '99. (you had to buy the incomplete vehicle -cab n chassis - no bed, for the 4wd option.)
2.an f250 w/ it's front ttb leads to a much lower sitting 4wd dually over an f350 drw cab n chassis (or converted 350 pickup) even though you get the less favorable ttb axle,it's lower ride height makes for easier loading the bed and the fuel economy is better than a higher sitting truck as well.
if both trucks are just 2wd's,then they're identical trucks anyway and it doesn't matter which way ya go.just go on price.
Old Aug 21, 2013 | 08:56 AM
raystankewitz
OP says its a 2wd, so in that case, he should find a DRW F350.
Old Aug 21, 2013 | 11:54 AM
snowdog79's Avatar
snowdog79
Not to be a downer, but why would you want to make a F250 a DRW? Changing it over doesn't raise the GVWR, actually lowers the payload and tow ratings (the DRW setup adds weight to the truck), lowers fuel economy, and increases maintenance costs (6 tires vs. 4). Since a F250 has a relatively low GVWR, I can't see the DRW adding any significant advantage in terms of stability at any factory-rated load.
Old Aug 21, 2013 | 12:14 PM
kermmydog's Avatar
kermmydog
Smile
The only advantage I see is if you aren't paying attention to GVWR ratings the dual rear tires will give you better stability & safety with heavy loads.
But why not just buy an F350 2wd there are plenty of them around.
Craig
Old Aug 21, 2013 | 05:49 PM
TheOtherStyle
either that, or buy a (very expensive but done right) dually conversion kit from Adaptors, Wheels, Duality Fenders and Complete Kits - Arrowcraft :: Helping You Handle the Road for over 30 years! Arrowcraft.
Just sayin'
Fair enough, thanks!
Craig
I'm getting the F250 for an absolute steal (trading my Ranger for it), I was just thinking ahead to stuff that I might be doing with it, and the thought came across. Figured I'd start looking for the info. If I was actually throwing down cash to buy it, it'd be a different story.
Old Aug 21, 2013 | 06:50 PM
IhDriver's Avatar
IhDriver
I've never done a conversion like this, but I used to have an old F-150 that I built up (Lifted, big tires, intake...etc...) These days you could go out and buy a Raptor. If I want to be able to haul loads like an 18-wheeler, i'm gonna add another axle, maybe put a lift and use 24" rims. Or why don't I just go to the next auction and buy an old Ford 8000 for $9000 and be done with it. Building a truck and buying a truck are two different things, the feeling you get from building one is a heck of a lot better than buying one.
Sorry, little bit of a rant. A lot of people bug me about that. Anyways, my truck has the Ford Sterling 10.25 limited slip (4.10 gearing) rated at 7400. My GVWR is 10000 LBS. Why wouldn't the GVWR change if the OP did the conversion to his F-250, especially if its same motor, springs, axle etc... (cloned F-350) Might not change on the registration papers, but physically yes.
Forgot to add you can take corners like a champ with a dually!
Old Aug 21, 2013 | 07:03 PM
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by IhDriver
...Anyways, my truck has the Ford Sterling 10.25 limited slip (4.10 gearing) rated at 7400. My GVWR is 10000 LBS. Why wouldn't the GVWR change if the OP did the conversion to his F-250, especially if its same motor, springs, axle etc... (cloned F-350) Might not change on the registration papers, but physically yes.
Where are you getting that astronomical 7400lb number? My dually does not have that high of a rear axle GVW
At the end of the day what the truck is REGISTERED to haul is all that matters.
Old Aug 21, 2013 | 08:24 PM
IhDriver's Avatar
IhDriver
Axle code D5
4.10 gearing 7400LBS Ford Limited Slip (I'm assuming it's in LBS, here we work in KGs, so..... LOL)
Ford Axle Code Chart .: Articles
True enough, but here it also depends on whether you haul for personal or commercial reasons. Everywhere is different
BTW, I am not sure if it is true, but the D5 axle code might only be in our Canadian trucks, can't remember where I heard that but correct me if I'm wrong...
Edit: I understand that just because the axle can "support" that weight, doesn't mean the rest of the truck can. The GVWR (10000LBS) is the important part. So if the truck weighs 7000LBS (example) leaves only 3000LBS for payload right?
Sorry if it makes no sense, I'm used to KG's...
Old Aug 21, 2013 | 08:38 PM
Diesel_Brad
Axle code D5
HA, 7400lbs I am pretty sure you will bend or brake something
Old Aug 21, 2013 | 09:06 PM
IhDriver's Avatar
IhDriver
ah, for sure! I don't think the bed would even enjoy that LOL Anyways, my original point is that if the OP is thinking about converting a SRW to a DRW, got the funds, time and patience (and some help) GO FOR IT. Around here you don't see many dualies anymore let alone older ones.
Cheers!
Old Aug 21, 2013 | 09:56 PM
blkF250HD's Avatar
blkF250HD
IMO the only reason to have a dually is if you plan on using a slide-in camper or plan on hauling a 5th wheel. Going from a Ranger to an F250 is a huge leap in capability, and unless you're hauling horses or equipment on a regular basis, you should be fine as-is.
Old Aug 21, 2013 | 10:39 PM
kermmydog's Avatar
kermmydog
Smile
What year Ranger 2 or 4 wheel?
I agree with you. Unless your planning on hauling big loads keeping the Ranger might be the better option.
Old Aug 22, 2013 | 12:01 AM
TheOtherStyle
98 Ranger, 2.5L 4cyl, 5spd, 2wd. Single cab stepside. It's been a great little truck, has over 235k and still runs like new and gets 28mpg on the highway. I'd love to keep it, but my business has been growing and it's just too small now.
