Sponsored by: Real Truck
obd scan tool won't link
Old May 22, 2012 | 03:13 PM
2004F250superduty4X4's Avatar
ok i have 2004 super duty 5.4L 4x4. i posted a thread some months ago about my obd scanner not connecting to pickup. still having the issue. happened to have the truck at the ford house the other day and they couldnt connect to it either. cigarette lighter is working, the picture of engine light appears on the dash when you turn on the ignition. any suggestions as to what else to try?
Old May 22, 2012 | 08:26 PM
Speicher's Avatar
Speicher
Check your terminals at the Data Link connector, make sure none of the terminals are spread causing a loose connection, seen this on several occasions.
Use your scanner terminal as a reference of the size pin you need and ck. for a slight drag at each terminal. You want to be carefull not to use something to large and cause damage to the terminal. Possible straight pin, paper clip etc. Ck your voltages at the DLC , top row 1-8, bottom row 9-16. SCP bus terminals to ground if I remember correctly between 2.5-3.5 volts with the key on.
x 12345678 x
x 90123456 x
Pin 2 TN/OG SCP Bus
Pin 4 BK Ground
Pin 5 BK/WH Ground
Pin 10 PK/BK SCP Bus
Pin 16 Voltage Supplied At All Times, Fuse 2.12 20 amp LB/WH
Old May 23, 2012 | 07:38 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What brand/model obd-ii scanner is it?
Old May 28, 2012 | 03:55 PM
Ok scan tool
Is a innova 1303 with all the newest updates, including the abs upgrade
Old May 28, 2012 | 04:28 PM
projectSHO89's Avatar
projectSHO89
Did you check for battery voltage on pin 16 or the connector?
Remember, it's supplied by the cigar lighter fuse and is usually mandatory for most scanners to operate.
LCA078
23
Jun 14, 2024 01:42 AM
1973FE
22
Apr 13, 2019 11:56 PM
HughLee
Mar 27, 2017 09:00 PM
finallyo3gt
17
Nov 14, 2015 10:43 PM
77300i6
1983 - 2012 Ranger & B-Series
Oct 15, 2007 08:55 AM
