Finding TDC on '91 4.9
I'm in the final stages of an engine swap and needed to swap in my old distributor since the donor engine was a '93 with the remote TFI.
So I'm trying to set the engine to TDC by spinning it around by hand. I've got #1 spark plug out so that I can confirm it's at TDC.
There are two marks on the crank pulley - a notch and a scribed line. Which one should I be using, and what do I align it with? Neither seems to be lining up with the TDC mark on the timing cover, but it occurs to me as I'm typing this that maybe it shouldn't, and it should be aligning with that little round "window" over on the passenger side - yes, no, maybe?
Normally the notch on the balancer would line up with the TDC mark. If it's slipped that might explain the scribed mark.
Here's how we've always done it. Pull the valve cover so you can watch the valves, place your finger over the spark plug hole. Rotate the engine until it stops hissing around your finger AND The valves are both closed. That will be TDC on the compression stroke. That's where you want it, otherwise you'll be be 180 degrees out.
Could be you're looking at the wrong timing mark.
The back of the damper has a notch in it which is not the timing mark.
The timing mark is a scribed mark that can be very hard to see.
Some people use sand paper on the damper to get the rust
off of it which makes it easier to find the timing mark. Once you find the
mark use white paint on it so it can easily be seen.
The first picture shows the mark.
The second picture shows the notch.
The third picture shows the notch and the scribed mark.
Looking from the back side of the damper, the scribed mark is about
7 1/4 inches in the ccw direction from the notch.
The timing numbers are on a saw tooth shaped piece of metal that bolts
to the timing cover and is on the passenger side of the timing cover.
The timing cover also has timing marks engraved in the timing cover
on the driver side. These timing marks are not used for a fuel injected engine.
The fourth picture shows the timing numbers on the sawtooth shaped
piece of metal.
<TABLE id=ncode_imageresizer_warning_2 class=ncode_imageresizer_warning width=400 itxtNodeId="1031" itxtHarvested="0"><TBODY itxtNodeId="1057" itxtHarvested="0"><TR itxtNodeId="1058" itxtHarvested="0"><TD class=td1 width=20 itxtNodeId="1060" itxtHarvested="0"></TD><TD class=td2 unselectable="on" itxtNodeId="1059" itxtHarvested="0">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
<TABLE id=ncode_imageresizer_warning_4 class=ncode_imageresizer_warning width=400 itxtNodeId="1028" itxtHarvested="0"><TBODY itxtNodeId="1062" itxtHarvested="0"><TR itxtNodeId="1063" itxtHarvested="0"><TD class=td1 width=20 itxtNodeId="1065" itxtHarvested="0"></TD><TD class=td2 unselectable="on" itxtNodeId="1064" itxtHarvested="0">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
<TABLE id=ncode_imageresizer_warning_5 class=ncode_imageresizer_warning width=400 itxtNodeId="1025" itxtHarvested="0"><TBODY itxtNodeId="1067" itxtHarvested="0"><TR itxtNodeId="1068" itxtHarvested="0"><TD class=td1 width=20 itxtNodeId="1070" itxtHarvested="0"></TD><TD class=td2 unselectable="on" itxtNodeId="1069" itxtHarvested="0">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
<TABLE id=ncode_imageresizer_warning_3 class=ncode_imageresizer_warning width=400 itxtNodeId="1022" itxtHarvested="0"><TBODY itxtNodeId="1072" itxtHarvested="0"><TR itxtNodeId="1073" itxtHarvested="0"><TD class=td1 width=20 itxtNodeId="1075" itxtHarvested="0"></TD><TD class=td2 unselectable="on" itxtNodeId="1074" itxtHarvested="0">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
<!-- / message -->
Suffice it to say, I am now very good at removing the distributor, rotating it 180 degrees, and re-installing. I presume there is no other way to verify that you're at TDC-Compression stroke short of looking at the valves?
<table id="ncode_imageresizer_warning_3" class="ncode_imageresizer_warning" itxtnodeid="1022" itxtharvested="0" width="400"><tbody itxtnodeid="1072" itxtharvested="0"><tr itxtnodeid="1073" itxtharvested="0"><td class="td1" itxtnodeid="1075" itxtharvested="0" width="20">
</td><td class="td2" unselectable="on" itxtnodeid="1074" itxtharvested="0">
</td></tr></tbody></table>
<!-- / message -->
<!-- / message -->
El Caballo
02-14-2019 09:28 PM
