SRL+
Old May 21, 2012 | 11:26 PM
MisterCMK's Avatar
MisterCMK
Smile SRL+
How much boost do you guys see with the SRL+ tunes? I am working with Matt on getting my truck dialed in but am curious as to what you see for boost from a WOT run and also rolling into the throttle in overdrive with the converter locked. What do you see for exhaust temps?
Old May 22, 2012 | 08:33 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Can't help you with true boost numbers since I'm reading from the OBD port, but I've seen the EGT's get up around the 1500 degrees in top gear at wot.
wannabe7.3
Feb 25, 2015 02:15 PM
diesel-fitter-bum01
23
Dec 9, 2009 05:54 PM
UGA33
Mar 29, 2008 06:12 AM
fireman660r
Jan 11, 2008 03:01 PM
dtruzinski
May 30, 2004 12:04 PM
