Sponsored by: Real Truck
Ball Lube
Old May 21, 2012 | 11:07 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Ball Lube
Do you lube your ***** or do you hook up and go?
Old May 22, 2012 | 05:32 AM
2000silverbullet's Avatar
2000silverbullet
Mostly dry. Coating it in something is always an afterthought, at which point I no longer care.
BTW - congrats for the featured truck piece on ford.com (showed up on FB, I thought it looked familiar).
Old May 22, 2012 | 06:18 AM
critterf1's Avatar
critterf1
That could be a "loaded" question.
Old May 22, 2012 | 07:35 AM
counciller's Avatar
counciller
Always use lube - it just makes life easier
Old May 22, 2012 | 07:54 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I dont usually lube my ball, after unhooking you cant get within 2 feet of it or your going to end up with the lube on you. If you just have to use lube just rub a little vaseline in.
Old May 22, 2012 | 08:03 AM
RickBetterley's Avatar
RickBetterley
I do use the lube, but as noted, it is really messy.
Old May 22, 2012 | 12:48 PM
bpounds's Avatar
bpounds
For years I didn't believe it was necessary to lube the tow ball. Then one year, after towing cross country, I arrived and found the nut partially loosened on the ball. Scary, and I didn't need a second lesson.
I just buy the small container of lube at the trailer supply place. Nice small container with a screw on lid, so it stays neat and tidy, easy to carry. It will probably last a lifetime if used sparingly as it should be. Works for fifthwheel pins and WD hitch bars too.
As far as the mess, a ball cover helps keep your pants clean.
Old May 22, 2012 | 02:29 PM
swheeler's Avatar
swheeler
Lube your ball. If you don't, eventually, it will wear right through the top of your coupler.
Old May 22, 2012 | 02:38 PM
phantomphixer's Avatar
phantomphixer
Lube my ball. Also put a little lube on the receiver receptical.
Hard not to laugh when writing this.
Old May 22, 2012 | 03:55 PM
1975StroppeBaja's Avatar
1975StroppeBaja
I lubed my ball just the other day. Always do before hooking up.
Seriously though, I do. LOL.
Old May 22, 2012 | 06:28 PM
Hotpocket's Avatar
Hotpocket
i have never lubed up
Old May 22, 2012 | 07:11 PM
SMOKEPLOE's Avatar
SMOKEPLOE
when ever i tow the boat i lube it up.
i have an old tennis ball that is cut so it slips over the ball, i just press the btennis ball down and turn a couple of times since i have loaded it with axle grease-- no fuss no muss
smokeploe
Old May 22, 2012 | 08:15 PM
SDTriton250's Avatar
SDTriton250
I only have one big ball but I lube it before every trip with a pull along. Any lube works. Motor oil if nothing else. Same with the pin on the 5th wheel. The plate gets a clean nylon disc.
Old May 22, 2012 | 08:36 PM
98SurplusExpy's Avatar
98SurplusExpy
I lube both my 1 7/8" & 2 5/8" *****. =)
SRBF150
27
Mar 7, 2019 03:32 PM
pony
Jul 10, 2013 08:56 PM
crazy96863
Apr 6, 2012 09:21 PM
gerald tompkins
Jan 31, 2010 06:59 AM
m@m
2004 - 2008 F150
Dec 8, 2007 08:41 PM
