upper ball joint
Old Jan 30, 2010 | 11:28 AM
gerald tompkins's Avatar
gerald tompkins
upper ball joint
i have a 1999 SD 4 WD that i replaced the ball joints on. there is very little room between the grease sert on the top and the axle.i used boog ball joints,and on the top i used a 90 degree grease sert.is there anything that anyone did different that gave them more room? thank you for any info you could give me.
Old Jan 30, 2010 | 12:21 PM
Kwikkordead's Avatar
Kwikkordead
I used a straight zerk, but with a 90 degree fitting on the grease gun.
The zerk is very short so the clearance is there for the axle to rotate.
Using the 90 degree fitting, rotate the axle to allow the clearance to get in there and lube the ball joint.
You can get them at NAPA.
Old Jan 30, 2010 | 05:45 PM
gerald tompkins
well thank you very much kwikkordead fot the info.were going to try that and see what happens.boy i am glad this forum is hear,it has helped me on a few problems.
Old Jan 30, 2010 | 06:19 PM
ChunderDownUnder's Avatar
ChunderDownUnder
Had the same problem
Just put in a 90.
Man its tight in there but I have been 4wd'n a few times and it dont touch.
Old Jan 30, 2010 | 09:03 PM
mueckster's Avatar
mueckster
This is what I use to grease the small straight fitting. More clearance that way. I have heard the 90* fitting can get knocked off while turning in 4x4.
Old Jan 30, 2010 | 09:20 PM
ChunderDownUnder
Might have to hunt one of those down Roland. I can still see having troubles with that one if the Knuckle is in the wrong position. ??
Old Jan 30, 2010 | 10:36 PM
gerald tompkins
thanks for the info everyone.i think i will install a straight short zirt and try that.
Old Jan 31, 2010 | 06:42 AM
damicofuel's Avatar
damicofuel
yup, go with the straight one, I cleaned both of my 90s off of my new moogs
Old Jan 31, 2010 | 06:59 AM
DieselCamper01's Avatar
DieselCamper01
I was ablr to get a slightly lower profile 90 at NAPA that worked but I will change over to the straight when I do the passenger side.
