No Start
Old May 21, 2012 | 06:59 PM
fbrtransbear's Avatar
fbrtransbear
No Start
Problems started a while back, long crank to start, sometimes a missed start, intermitennt check engine light that would go away, then drove all day start and stop in town, no problems until the next day when it wouldn't start. The engine cranks and fires on a couple of cylinders but will not complete the start. I'm getting some smoke at the tail pipe so I'm getting fuel but it dies before it completes the start.
2006, 6.0, 80,000 mi.
Thought I was loosing a battery so I replaced the batteries while I was waiting for my Scangauge II. Didn't think about loosing the stored codes when I disconnected the batteries.
Scangauge detects no codes so I'm not sure where to go from here.
Old May 21, 2012 | 07:22 PM
BLADE35's Avatar
BLADE35
Lets Program the ScanGaugeII with some X-Gauges
The ScanGaugeII isnt the Best Code/DTC Reader you could still have a Code in the PCM IDK
Best bet at this Point is program X-Gauges and start checking the sensors out
ICP
Inj. Control Press. TXD: 07E0221446 RXF: 046205140646 RXD: 3010 MTH: 003900640000 NAM: ICP
IPR %
IPR Duty Cycle TXD: 07E0221434 RXF: 046285140634 RXD: 3008 MTH: 0DCA03E8000A NAM: IPR %
FLP
FICM Logic Power (Volts) (Should be 12 volts) TXD: 07E02209CF RXF: 0462450906CF RXD: 3010 MTH: 0064010000000 NAM: FLP
FMP
FICM Main Power (Volts) (Should be 47-48) TXD: 07E02209D0 RXF: 0462450906D0 RXD: 3010 MTH: 0064010000000 NAM: FMP
FVP
FICM Vehicle Power (Volts) (Should be 12 Volts) TXD: 07E02209CE RXF: 0462450906CE RXD: 3010 MTH: 0064010000000 NAM: FVP
FSS Fan Speed Sensor (RPM) TXD: 07E022099F RXF: 04620509069F RXD: 3010 MTH: 000100040000 NAM: FSS
FPW Fuel Injector Pulse Width (microseconds) TXD: 07E0221410 RXF: 046205140610 RXD: 3010 MTH: 000800010000 NAM: FPW
Lets start with these X-Gauges if a Gauge dont work let us know there are Alternate Codes to try
Old May 22, 2012 | 09:14 PM
fbrtransbear
No Start
I guess I am missing something. How do I program X gauges? Not sure what you are talking about. The scan gauge seams to take forever to connect or I have to force the connection.
Old May 22, 2012 | 09:30 PM
BLADE35's Avatar
BLADE35
That SGII isnt the best code reader BUT
Were all getting it because of it ability to program specific Gauges with the Codes I mention Above
Each Code is a Gauge theres a code for just about every sensor on the 6.0L
Basicaly from the Home screen you hit MORE-MORE-MORE untill you get to the screen that says X-Gauge then select EDIT and type the Code In it in whatever Slot you want
Theres a Vidio on you tube I think about it
Old May 22, 2012 | 10:18 PM
fbrtransbear
Thanks, I'll check it out tomorrow. Don't mean to be such a dunce but this is all new to me, I appreciate the help.
Barry
Old May 22, 2012 | 10:42 PM
steelhead2's Avatar
steelhead2
Try plugging it in. Sounds like youve got an ficm thats a goner.
Old May 23, 2012 | 01:50 AM
Yahiko's Avatar
Yahiko
Rusty Axlerod posted link for the video how to
https://www.ford-trucks.com/forums/1...l#post11774317
There is a good list of the X-codes also.
Just look down to the lower posts
Sean
Old May 23, 2012 | 12:24 PM
fbrtransbear
Scangauge
Blade35:
Scangauge isn't going to work for me. Been trying to program the first gauge for about an hour, the gauge keeps going to sleep then it makes me start over. I don't have the rest of my life to try and make this work, is there another way or a tool that is easier to work with. Computers are not my strong suit.
Barry
Old May 23, 2012 | 02:04 PM
fbrtransbear
Scangauge
Since my last post I have repeatedly attempted to program the scangauge. If this is what we have to work with we are doomed. This is a POS. Before I can get the info in it either goes to sleep or changes screens. I will be sending it back. I don't have time for this nonsense.
Old May 23, 2012 | 02:32 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
press the main button till you come to xguage then press that one to go to that area. Let me see if I can find the video I was sent.
U tube will surely have it
Old May 23, 2012 | 03:57 PM
BLADE35's Avatar
BLADE35
Start the truck and program it while running
I know what you mean mine turns off to have to enter codes fast enough to keep it awake or have truck running so I start the truck to program it
Just Start the truck after you get a couple Gauges in it you will Fly right threw it and be a PRO in no time
its not that Bad you will get the Hang of it We all struggled at first
Duh BENNY the truck wont start
Stick it into another Vehicle to program it while running It will still retain all the X-Codes you have entered when you unplug it and swap cars. The only thing you lose when unplugging it is the MPG stuff and some of the specific vehicle Info But all Codes will remain or should
then you can dial in the MPG and vehicle info Later when you get it running but at least you will see the Important sensors NOW
I know it didnt work like this for you but the Best Case senerio here is to get the SGII all setup and go threw what gauges work vs the ones that need an alternate code to make it read the PID some codes/gauges will need alittle altering because of Model Year and PCM Stratigy just the Nature of the Beast
Iv had mine for a Year now and am just barly getting sorted threw all of it with the right Codes/Gauges that work for me. It dawned on me I should get all gauges squared away with the truck running right and correct readings so I wasnt wondering if my code was reading right vs a Bad Sensor in the Mix trying to do it all with a Broken truck to complicate Matters
But Hang In there you will get it all straightened out
Old May 23, 2012 | 04:31 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
ie: Programming the ScanGauge II. It's a MUST to keep the truck running to set it up.
Old May 23, 2012 | 04:34 PM
mhatlen's Avatar
mhatlen
Benny I have a clip of video in one of my old posts but have no clue how to move it here.
Old May 23, 2012 | 04:46 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Just copy/paste the url here.
Old May 23, 2012 | 04:50 PM
BLADE35's Avatar
BLADE35
At the post with vidio
At the bottom right corner select Multi quote post turns the little thing red when selected
then come back to this thread and hit reply to thread at the bottom by trackback it will say you have a post selected and if you want to inclued it in your reply so select it and it will add it to reply
or thats on way
or you can hit permalink then right click address bar at top copy it then come to this thread and reply and then right click and Paste it here
It took me a few to figure out how to do that stuff computers and me dont get along
