Removing Rusted Studs Help
Old May 21, 2012 | 05:08 PM
Journeymaaann's Avatar
Journeymaaann
Hi - I know you guys have the answer to my problem. I am trying to remove the front & rear drive shafts & don't want to destroy parts doing it. I tried PB Blaster for a couple of days on the rusted studs holding the flange to the front drive shaft. I figured heat would be next but thought I would check here.
Thanks!
Old May 21, 2012 | 05:16 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
I believe you need a torch, those are 12 point studs and will strip easy. Try it without first and see what happens.
Old May 21, 2012 | 06:30 PM
cps's Avatar
cps
You could try and get a 12pt box end wrench a little bit smaller than the stud and hammer it on. It will bite into it and you should be able to turn it. i have used this method before and works as long as you have the clearance.
Old May 21, 2012 | 06:33 PM
just another truck's Avatar
just another truck
I would suggest the heat, and an impact driver, with 12 point, of course
Impact Driver Set | AutoZone.com
Old May 21, 2012 | 09:14 PM
Journeymaaann
Thanks for the help, I'll let you know how I do, and keep those answers coming! This is as much fun as cheating on a test & its Legal!
Old May 23, 2012 | 05:07 PM
racincowboy's Avatar
racincowboy
There is some stuff I use called Fluid Film that you can get online or from a John Deere dealer. The stuff is used on off shore oil rigs for rust prevention and lubrication. I know you are wanting to get these apart but I would try it. When you spray it on there it will foam up.
The Fluid Film is not solvent based so it doesnt dry out and will prevent further rust from forming. I thought they were a sponsor on here at one point someone was giving away free samples thats where I found out about it. Hope it helps
Old May 23, 2012 | 07:22 PM
helihansen's Avatar
helihansen
If you dont have a torch you can get one from any hardware or auto parts store for like $20, Get "Mapp" gas its hotter than propane.
Old May 23, 2012 | 09:17 PM
Rose Clifford's Avatar
Rose Clifford
Use heat and cold to break the rust free. Torches work great for heat and a can of keyboard/computer duster upside down provides some decent on-point cold. Any CO2 can will do, but duster cans are large and come with a accurate nozzle.
Old May 23, 2012 | 09:50 PM
WA.Ranger's Avatar
WA.Ranger
These work awesome if the heads strip.
10 pc. Impact Grade Bolt-Out™ Damaged Bolt/Nut Remover- Craftsman-Tools-Auto & Mechanics Tools-Taps & Dies
I would do as all the above have said.
V10man
Modular V10 (6.8l)
Jan 7, 2015 03:31 PM
RickTFL
Apr 29, 2014 12:14 AM
KoolAidMan888
Jun 4, 2012 09:25 AM
F-250 restorer
Jun 25, 2011 05:32 PM
dbuck50
Nov 21, 2007 05:27 AM
