2000 7.3 WONT START
Old May 21, 2012 | 12:48 PM
THE HOGG's Avatar
THE HOGG
2000 7.3 WONT START
IT TRIES TO START BUT THEN JUST DIES. I PUT MY HAND ON THE FUEL PUMP UNDER THE TRUCK WHEN SOMEBODY TURNS IT ON AND I CAN FEEL IT CLICK BUT NOT RUN. SHOULD IT COME ON AND RUN FOR A SHORT TIME? NOT SURE WHAT ELSE TO CHECK. IVE TRIED THE SEARCH FUNCTION BUT AM NOT HAVING ANY LUCK. THANKS IN ADVANCE FOR THE HELP.
Old May 21, 2012 | 01:10 PM
landmobile's Avatar
landmobile
The fuel pump should run for about 20 seconds with the key on and engine not running. Here's a quick way to check it:
Locate the drain tube coming from your fuel water separator drain (it's on the front of the engine, above the front axle.) Add a short length of hose to the drain tube and run it into a bucket. Open the fuel drain (yellow handle located on the rear of the fuel filter bowl). When the key is turned on you should see a good stream of fuel flowing into the bucket (about 1 gpm).
Don't know if it will solve your problem, but its a quick test to see if the fuel pump is running.
Chris
Old May 21, 2012 | 03:18 PM
THE HOGG's Avatar
THE HOGG
THAT WAS IT. THANK YOU SIR!
Old May 21, 2012 | 03:25 PM
landmobile's Avatar
landmobile
You're welcome, glad you got it figured out.
evans.brett87
Dec 12, 2018 08:48 PM
Skip1970
179
Feb 2, 2012 02:27 PM
edub32
35
Oct 5, 2008 07:15 PM
TLR1077
Apr 6, 2008 08:05 AM
messeswithtrux
Feb 11, 2008 09:22 AM
