time to replace the turbo
Old May 21, 2012 | 07:25 PM
fordpride's Avatar
fordpride
Originally Posted by jchosler
I was thinking going with the beans turbo but wasnt sure if it was a direct bolt in or not. Also what are the other turbos worth looking into that are direct bolt in?
What are you planning on doing with your truck?
If it's just a DD, tow rig, and sometime play I'd go with a s366 or a s465
Note as of Travis to put a s400 frame in a OBS you will have to cut and beat back the fire wall in the turbo area to get it in.
Old May 22, 2012 | 09:58 AM
jchosler's Avatar
jchosler
Just talked to Jake at Irate Diesel for a bit about the s366 and his turbo only works when you have electric fuel due to a return line he uses where the mechanical pump used to go so I ended up going with the beans because I can't do electric fuel right now
Old Jun 7, 2012 | 05:34 PM
jchosler's Avatar
jchosler
Does anyone have a link to an D66 install page?
Old Jun 7, 2012 | 10:27 PM
jchosler's Avatar
jchosler
How about for a stock turbo?
Just unsure on torque specs and if there's a gasket between the turbo and pedestal
Old Jun 7, 2012 | 11:02 PM
fordpride's Avatar
fordpride
It got two o rings in-between the ped and turbo
Old Jun 8, 2012 | 06:41 AM
DIYMechanic's Avatar
DIYMechanic
The only gasket is between the collector and the exhaust side housing. Everything else is sealed by o-rings.
Old Jun 8, 2012 | 09:05 AM
jchosler's Avatar
jchosler
do I need lock tight? Anyone know torque specs?
Old Jun 8, 2012 | 11:14 AM
pjwoolw's Avatar
pjwoolw
No LocTite. Nickel anti sieze is what you should use. Your not going to be able to get to all the fasteners to torque them so get as close as you can by feel. Leave the flange to the downpipe off the turbo and install it last.
Pedestal to Engine Mounting Bolts 24 Nm / 18 ft lbs
Exhaust Back Pressure Valve to turbo 6-7 Nm / about 80 in lbs
Turbine Housing to Center Housing 20-24 Nm / 18 ft lbs
Turbo to up pipe flange 49 Nm / 36 ft lbs
dougbrown
Jul 22, 2014 12:14 AM
JaySVX
Jul 16, 2013 12:23 PM
427 fordman
Nov 26, 2012 12:43 PM
zhigaag
Mar 10, 2012 10:57 AM
thegreatwhitefarmer
Dec 16, 2009 05:45 PM
