352 timing
Old May 4, 2003 | 08:24 PM
Ford67ranger's Avatar
Ford67ranger
352 timing
I've had problems with my 352 backfiring through the carb upon hard acceleration. I Backed the timing off from several degrees BTDC to 0 degrees BTDC. Now it has started to run rough at idle and stumble but not backfire under acceleration, and I think the timing could be involved. The plugs seem good and the air-cleaner is only slightly dirty. What timing are ya'll running and what do you suggest i check or adjust it too.
Nathan
Old May 4, 2003 | 09:56 PM
gtex's Avatar
gtex
352 timing
You should be closer to 6-12 BTDC. Some of us run even higher with hot ignition setups or upgrade cams.
Get the timing back up to 8 or 10 and start looking for Carb problems.
Is this a recent problem. If so, did it happen suddenly? If so, your timing chain may have slipped. Otherwise, stick to the carb investigating.
Old May 5, 2003 | 07:47 AM
William's Avatar
William
352 timing
Are you using points? Or aftermarket electronic? Did this problem begin one day while you were happily motoring along or after you made some adjustments? I like initial timing at 12 degrees advanced. Of course you need good compression and a timing chain that is in good condition as well. A operating vacuum and centrifugal advance is also helpful. A crossed plug wire will cause this as well. Post back we want to know how this comes out. Oh yea, Dahn's law says "90% of poor running engines are caused by ignition problems".
Old May 16, 2003 | 11:23 AM
Ds7776's Avatar
Ds7776
352 timing
I think ill add my two cents and say that ive had this problem with my 66 f100 352. maybe youve gotten this problem fixed but what i did was replaced the power valve on the bottom of my carb and that curred it right up but later i swapped to a new Holley 500 cfm 2 bbl carb. And I havnt had any problems with it since, I also never messed with the timing, but due to recent problems i wish i could see the timing marks on the balancer.
jasindude1
Nov 3, 2019 11:37 AM
1989FordF250
16
Aug 10, 2017 07:45 AM
briguy
May 20, 2017 08:37 AM
coleaclark
37
Apr 11, 2008 02:07 AM
matt65f100
May 13, 2002 09:29 PM
