losing prime?
Old May 19, 2012 | 10:35 AM
Steelheader87's Avatar
Steelheader87
losing prime?
The old mans 84 would not start, so checked the fuel filter and was empty. Filled it full of fuel, starts and runs for about 30 seconds and dies. Checked the filter and empty, so I changed out the lift pump. Still having the same problem. The hard line from the lift pump to the filter was stripped and a SOB to get off and now leaking fuel. Would that be enough fuel leaking and air intrusion for the lift pump to not get enough fuel to the filter? Sorry for the long post, but wanted to give you all the info.
Old May 19, 2012 | 11:38 AM
kjgibson2's Avatar
kjgibson2
I would replace the line, and also turn the truck over and make sure fuel is getting to the lift pump, and its pumping up to the filter, air could be causing a blockage, by the lift pump should pump enough to make it run a little, your filter should not be empty, thats for sure
judging by what you wrote, i'd say your either not getting fuel to the lift pump, or...its not pumping, and if its new...well they are driven off the cam so....draw your own conclusion
Old May 19, 2012 | 11:47 AM
linus72's Avatar
linus72
make sure it's not either a broken pick-up tube in the tank and/or leaking return lines, also at the tank..
My problem was that I had a broken pick-up tube and a leak where the return line hooks to tank (front tank).
does it ever surge or stall on a hill?
Old May 19, 2012 | 11:58 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
fill the tank up,or at least half way if she's at a 1/4 or less.this will let ya know if the pickup tube screen fell off or not.
Old May 19, 2012 | 05:13 PM
Steelheader87
The front tank was low, so I filled it up close to full, to rule out pickup tube. The metal fuel line that has a stripped nut is leaking fuel, so wouldn't that mean fuel is getting to the lift pump, but not to the filter. The lift pump bolted right up, so can I assume I installed it properly? Would fuel leaking out of the hard line from the lift pump cause enough air intrusion to keep fuel from getting to the filter? Any ideas where to get that metal fuel line? International wants $92.
Old May 19, 2012 | 06:11 PM
tjc transport's Avatar
tjc transport
i ain't rite
there are two ways to put the lift pump in. the proper way is to tip the top up and insert the arm into the block, then tilt it down till you feel tension on the arm from the cam to screw it in. if you just stuff it in there, there is a good possibility the arm will go over the cam eccentric. if this happens, the eccentric will wipe out the pump arm as soon as you try to start it.
the last one i did had a bad nut on the line. i cut the line, got a new nut from NAPA, and reflaired the line. then i cut the steel line and added a short piece of rubber fuel line to extend it so it would fit.
Old May 19, 2012 | 10:17 PM
FORDF250HDXLT
just ditch the metal line.no need to pay 90 bucks for a short piece of low pressure fuel line.metal or not.
just screw in a fitting that accepts a fuel hose and run that to your lift pump.
if your leaking fuel,she's sucking air for sure.
this is what i did when i swapped to an electric fuel pump.but i can't find a pic that shows the fitting.this is the closest i see:
https://www.ford-trucks.com/forums/a...1&d=1334695289
but you get the idea anyway.cheap and KISS.
sorry forgot the size though.just take your stripped out metal fuel line with ya to the parts store.tell 'em you need a fitting to match the threads and a hunk of 3' low pressure diesel rated fuel hose.they'll set ya right up for pennies on the dollar compared to that stock metal piece.
Old May 19, 2012 | 11:13 PM
Steelheader87
Thanks for the info. I am going to take FORDF250HDXLT's advice and replace the metal fuel line with new fittings and fuel hose. Thanks again.
Old May 20, 2012 | 08:59 AM
Steelheader87
What is the electrical connection on that metal fuel line?
Old May 20, 2012 | 11:20 AM
farmert's Avatar
farmert
On the 6.9 that is the fuel heater. Disconnect the wire and tape it off, as the heater is not needed.
Old May 20, 2012 | 01:29 PM
Steelheader87
Great, thank you.
Lysandra
16
Jan 11, 2018 09:37 AM
FordAnne
Nov 11, 2017 11:03 AM
mark's1984
Mar 25, 2016 05:23 PM
Steelheader87
Jun 11, 2012 03:52 AM
texasjack
Dec 9, 2008 09:24 PM
