Ford 9" differential fluid
Old May 19, 2012 | 08:40 AM
hermancm's Avatar
hermancm
I'm thinking about changing the differential fluid on my Ford 9er, it looks like I'd have to suck it out as best as possible and refill it with gear lube?
Old May 19, 2012 | 08:54 AM
bertha66's Avatar
bertha66
Yes 80/90w gear oil. Sucking it out is one way, or drop the drive line and pull the 3rd member out to get a good cleaning of the inside of the housing.
Old May 19, 2012 | 10:38 AM
hermancm's Avatar
hermancm
I dunno
Thanks for the reply! I did a search of the forum and to pull the shaft and all I'd have to pull the axles out some too. I suppose that means brakes and bearings and the whole sha-bang! HS! And one responder said he couldn't get JS out of his pumpkin with even a 1/4" tube.... Maybe there was nothing in there to get any longer? I'll try to suck some out and refill it and MAYBE... Get into it more sometime later. Itd sure help to have a garage up here! Thanks again!
Old May 19, 2012 | 10:50 AM
Oldbone's Avatar
Oldbone
If you do decide to pull and drain it. I would suggest drilling and tapping a hole for a drain plug in the bottom while you have it open. Shame on Ford for not having one in the design.
Old May 19, 2012 | 04:14 PM
meborder's Avatar
meborder
i did this on my D70. Didnt want to spend the time removing the cover, so i just sucked it out and refilled it.
i used 85w-140 synthetic blend. but i was also trying to solve a traction loc shutter ... which i did. The stuff i used was rated for LS diff's without the additive, and it has worked wonderfully.... Valvoline IIRC.
anyway, if it were me, i'd just suck it out and refill it. you'll get 90% or better of the old fluid out doing it that way ... that will solve most problems, in my experience anyway.
Old May 19, 2012 | 06:30 PM
bertha66's Avatar
bertha66
[QUOTE=hermancm;11852986]Thanks for the reply! I did a search of the forum and to pull the shaft and all I'd have to pull the axles out some too. I suppose that means brakes and bearings and the whole sha-bang! HS!
No, you do not have to the brakes to get the axles out, just the brake drums. the four bolts that hold the axles in are inside the backing plates, access though the hole in the end of the axle.
Old May 19, 2012 | 06:35 PM
Tees77f150's Avatar
Tees77f150
Yup, and once you pull those axles out of a rear thats been together for 30 plus years, you may find more then you bargained for. Or at least axle seals that now want to leak since they have been disturbed. You could end up with dumping $300 into a rear you were not anticipating on.
Old May 19, 2012 | 10:36 PM
hermancm's Avatar
hermancm
I found a web page on rebuilding the Ford 9 inch with pictures and yes, they just had the drum removed and the axles pulled out a foot or so. But I'll go ahead and suck out the fluid and refill then call it good. That'll be after I replace the oil pan gasket that has blown out by the starter. A mechanic told me it was a common problem on the 4.9L's. He also said that I can replace the gasket without pulling the motor on a 2WD.
Thanks again!
Old May 19, 2012 | 10:57 PM
PRIMERED79 SHORT BED's Avatar
I think i read you can double nut the bottom stud and unscrew it and drain it that way.
I haven't made it that far on my beater, but I'm heading that way.
Old May 19, 2012 | 11:57 PM
HIO Silver's Avatar
HIO Silver
I run Royal Purple 80w/90 and a dose of LSD additive to keep the Trac-Lok alive.
The drum brakes need not be removed. Simply reach through the access hole and undo the axle retaining nuts to withdraw the axles. EZ. Unless ya mud bog often, installing a drain plug or other drain mechanism is just plain lazy IMO. It only takes about an hour to do it the factory way.
Old May 20, 2012 | 01:32 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The easiest way is to remove the Pinion carrier and suck the fluid out. If you drop the 3rd member the oil will indeed drain (spill) out, but not all of it. So you'll need to suck or soak up the rest out anyways.
After that, drill and tap the bottom of the housing for a 1/4" NPT drain plug.
Josh
Old May 20, 2012 | 03:07 PM
Josh
How many quarts does it take to refill?
And where is a good spot to drill a hole for the drain?
I remember asking about the hole on another thread some time ago, but they never posted back a response or pics.
Old May 20, 2012 | 03:15 PM
Bullitt390's Avatar
Bullitt390
I drill dead center in the housing. Unless you're planning an extended magnet plug of some sort it isn't going to interfere with ring gear or anything.
The housing is plenty thick for a 1/8 or 1/4 pipe plug. Anything large than that will need a bung welded.
Don't remember on fluid capacity... I believe I usually bought around 3 quarts 80w90
Josh
Sous
Jan 1, 2015 05:53 PM
roostercrows
May 10, 2013 11:10 AM
redlightning93
Jun 8, 2008 10:21 PM
strokerfe
Dec 26, 2006 09:20 PM
errauntone
Nov 5, 2002 04:48 PM
