Timing
Old May 18, 2012 | 06:38 PM
rnuner's Avatar
rnuner
Timing
Ok I am new to having a real engine (no computer). So this a new learning curve for me. I am used to working with a engine that has a computer and controls everything. So to my question do I need a timing pointer to be able to get the timing correct of course with a timing light.
Old May 18, 2012 | 09:08 PM
williamwilliam's Avatar
williamwilliam
Yes, you need a timer pointer otherwise you will not know where to line the mark up on the balancer, which factory calls for 8 degrees. I run mine around 11 or 12 because I installed an HEI dizzy which is outstanding and well worth the money.
Old May 19, 2012 | 12:18 AM
rnuner's Avatar
rnuner
Thanks man I wanted to make sure. I found that factory setting was between 6-8.
jssblues
1978 - 1996 Big Bronco
Mar 6, 2012 01:08 AM
fairfield86f150
Apr 21, 2008 09:43 AM
mpmitche
Jul 17, 2003 09:45 PM
cocot
Jun 30, 2003 12:13 PM
