Dealing with a worn rocker arm stud - SOLVED
Old May 17, 2012 | 07:24 PM
zerfetzen's Avatar
zerfetzen
Besides my 390 truck, I also have a 69 302 Mustang. I've rebuilt a lot of the motor, new cam, lifters, pushrods, etc., on stock heads (which I know don't flow well, so, a budget build). No matter how many times I set the rockers, later that day or the next a couple will start ticking, where they didn't before I rebuilt it. I've checked everything a million times (2nd set of lifters, etc.), and am convinced a couple rocker arm studs are worn, so some lock-nuts are backing off when they shouldn't. How would you work with this? I'm thinking the cheapest idea is get another few locking nuts and put on top. Or is it better to use thread-lok of some sort? If so, how would you apply that, since it needs to be set when the engine's hot and the studs are oily. The cam is nothing special, a Comp Cams 260H, so I don't think it's backing the studs out. Any thoughts are good, thanks.
Old May 17, 2012 | 07:42 PM
mark a.'s Avatar
mark a.
Lifter preload should only be set with the engine cold. Do your heads have screw in studs with some kind of a lock nut ? Do you have guide plates ? How are you adjusting them ? How did you get the right length of push rod, did you check for the right push rod length ?
This ? probably belongs in the S.B. forum.
Old May 17, 2012 | 07:50 PM
zerfetzen's Avatar
zerfetzen
I don't know if 302 studs are screw in or pressed in, I was assuming pressed in. I thought lifter preload shouldn't be set cold because they have to run first to pump up with oil? I'm assuming since I don't know what guide plates are that it doesn't have them. It's been a couple years so I'm fuzzy now how I arrived at the right length pushrod, but I knew what cam was in it before, contacted Comp Cams, and figured it out with them. I think both cams call for factory length, but again, it's been a while. I'm also sure it's the right length because the majority of valves are fine, it's just a couple rockers. The car's mostly sat because I could never solve it, and now I'm getting back to it. Question is, assuming the rest is good, how would you deal with worn rocker studs?
Old May 17, 2012 | 08:19 PM
zerfetzen's Avatar
zerfetzen
By the way, I just looked to double-check, and I don't see any signs of the rocker studs being screwed in, I'm pretty sure they're press fit. It looks like I didn't answer your question about how I went about setting them, but it's lengthy. I have several engine books and also went by Comp Cams. I've tried setting half the valves when piston 1's at TDC and the other half with the crank 360 degrees later, but only did that once because I prefer turning it 90 degrees and going cylinder by cylinder according to the firing order. I would slowly snug them up until there's no slack, then turn it a different amount of distance farther according to different sources. Quarter turn. Half turn. 3/8s turn. I haven't done it in a while so maybe I'm getting that wrong now that I'm coming back to it. Point being, I've been meticulous and am sure it's the rocker arm studs, because that's all that's left. I'm hoping there's a better answer than yank the heads and take them to a shop, because those are some pretty awfully designed heads, but then the alternative is to get the coin for some Eddys I guess.
Old May 18, 2012 | 05:40 PM
zerfetzen's Avatar
zerfetzen
Figured it out on the small-block forum, so just in case it happens to someone else, here's the answer: The 302's rocker arm studs are press-fit. Measure the tops with a straight-edge to see if the one(s) in question have noticeably backed out due to a higher lift cam and/or simply age. In my case, they did. The solution's either to take them to a shop and have new ones pressed in, try to convert them yourself to screw-in style, or in the case of the 302's horrible factory flow, it's best to upgrade to new heads if you can afford it.
Old May 18, 2012 | 07:37 PM
Ken(Ark)'s Avatar
Ken(Ark)
If you are on a tight budget , you can drill a hole and pin the studs in so they don't pull out .
zerfetzen
May 19, 2012 08:11 AM
60 F100 4X4
Oct 28, 2010 10:04 AM
TxBrokenarrow
21
May 13, 2005 08:11 PM
freemanrebel
Oct 26, 2004 06:26 PM
TOUGHY17
Nov 6, 2001 10:27 PM
